GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
nola mike
replied to the thread
Mercruiser 3.0 won't "lock in"
vertical shaft in the drive. would be a good guess given your prop strike, but vid shows blown coupler.
Thursday at 10:02 PM
nola mike
reacted to
kd4pbs's post
in the thread
with
Like
Yep. Blown out coupler. Time to pull the engine.
Thursday at 10:00 PM
nola mike
reacted to
kenny nunez's post
in the thread
with
Like
A very good chance the vertical shaft is the problem.
Thursday at 9:59 PM
nola mike
454 mag mpi chuggles/stalls
can't you graph it with the diacom? and did you ever unplug the IAC?
Thursday at 9:51 PM
guy48065
Prop change on my bowrider
So the grinding marks that squared-off that edge weren't to remove casting flash, sprue, etc? The INTENT is to take a nice smooth edge...
Thursday at 9:47 PM
jimmbo
The Trailing Edge of the Cup, should be Sharp and Abrupt. the Water will separate Cleanly. Any Rounding of the Edge will cause the Water...
Thursday at 8:46 PM
K
kd4pbs
Caffeine good for sleepy old guy ?
Yep. I drink a cups of coffee every morning. Black. I like it to taste like coffee.
Thursday at 8:36 PM
K
kd4pbs
Thursday at 8:32 PM
T
tr@v1s
What do you mean by 'the vertical shaft'? The drive shaft to the lower unit? Pretty sure everything in the drive is good. You can see in...
Thursday at 8:32 PM
vroom ZOOM
I will put my light on it tomorrow.
Thursday at 8:29 PM
T
tr@v1s
Question now: Pull motor, pull out drive, or pull both? (I'd like to be on the water next weekend if possible, but also want to do it...
Thursday at 8:28 PM
K
kd4pbs
reacted to
svonadym's post
in the thread
Schematic Diagram for Vintage Faria Tachometer
with
Like
Thank you for your offer. See below. It sure looks like a resistor to me, but appreciate your input.
Thursday at 8:21 PM
K
kd4pbs
The chip in the upper left-hand side is a CS 2917 which is a frequency to voltage converter. That’s what takes the tachometer signal and...
Thursday at 8:18 PM
nola mike
so again, that MAP is increasing for no reason. shouldn't be with the IAC closing... I'm still curious as to what the timing is doing
Thursday at 8:15 PM
K
kd4pbs
Yeah, that’s a resistor for sure. The smaller ones are 1/4 watt ones and the one that is burnt is a half watt resistor. It makes sense...
Thursday at 8:14 PM
