GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
jerryjerry05
replied to the thread
Force 40 issues
That's fixable. Just square off the edges.
Friday at 5:48 AM
P
Pmt133
Caffeine good for sleepy old guy ?
So far haven't needed caffeine to get through a day. Everyone else I work with drinks it like water even on banker hours. Not gonna kill...
Friday at 5:48 AM
jerryjerry05
Can't open cover on a US Marine Force 50
Spraying can make it harder to start. IF?? the plugs didn't have rust on them when you took them out, the cylinders should be ok. You...
Friday at 5:46 AM
vroom ZOOM
454 mag mpi chuggles/stalls
Yes, the intake came from the old engine, and that is the only part I have not tried moving from the other engine, aside from the...
Friday at 5:41 AM
vroom ZOOM
Yes I can... havent tried unplugging the iac but will try that today.
Friday at 5:30 AM
a half a pot on the way into work. another 3-4 large cups . I tried not drinking coffee..... the court date is pending.
Friday at 5:19 AM
dingbat
I typically drink 2-3 cups of black coffee before leaving the house in the morning. Drink two more cups during my morning meeting with...
Friday at 5:16 AM
Grub54891
Gas guage
To ease your mind, put a meter on the tank feed wire and see if it has voltage, I bet not.
Friday at 5:05 AM
Grub54891
Marine Sea Foam
Sea foam "might" work. Also, you have to add enough for the amount of fuel you have. A car is usually around 20 gallons. A boat may be...
Friday at 5:03 AM
J
jlh3rd
Trailer bearing blowout. Need help with repair(s)
then something isn't right. I see movement in the grease the minute I start pumping. I had that happen one time only on one wheel due...
Friday at 4:57 AM
H
Hand Crafted Angling
1986 Starcraft Mariner 160
I flipped back and forth on what to do with and decided to fix it up. Scraping all of the crap the previous owner had on it before was...
Friday at 4:44 AM
A couple more I/O questions...
it does look like the one-piece Batwing motor killing exhaust manifolds.
Friday at 4:41 AM
Marine Sea Foam
sea foam wont clean a carb. what RPM are you getting on the motor. if its running lean, that is a good way to toast a motor. I would...
Friday at 4:39 AM
Gas guage
gauges should not have constant power. they should be powered by the ignition circuit. however some gauge air cores do not move to 0...
Friday at 4:36 AM
reacted to
flyingscott's post
in the thread
2004 Mercury 115 2 stroke - oil injection block off plate
with
Like
The 3 and 4 cylinder mercs had goid oil injection systems. No reason to delete them.
Friday at 4:34 AM
