C
Chuck4741444
replied to the thread
Lowrance warranty
I think you jave a good point. Battery 2. At the console was lower. So i swith to Battery 1&2 to charge 2 while running.
Saturday at 4:33 PM
C
cyclops222
reacted to
airshot's post
in the thread
Silliest Question on Fuel Mix - Thank you for your patience
with
Like
You and I would get into a lot of trouble, however when you live out in the country as I do, you can see the county doing it all the...
Saturday at 4:29 PM
C
cyclops222
reacted to
airshot's post
in the thread
with
Like
Anyone that thinks they are saving this planet by cutting back on their two stroke oul, needs a reality check. The amount of oil based...
Saturday at 4:22 PM
N
ntanner
1970s Starcraft SS 160 refinish
Decided to remove the motor and flip the boat. I couldn’t get to the hole to rivet while it sat on the trailer. Might strip the paint...
Saturday at 3:43 PM
ESGWheel
Water pump leak?
The little rubber cap on the anti-rotation bracket is nice to have but not critical. Item no. 5 of link. The inner seal does look...
Saturday at 3:40 PM
FLATHEAD
2025 NFL/CFB News and Nonsense
The verdict is in. James Franklin needs to pack his bags and hit the road and take Jim Knowles with him.
Saturday at 3:06 PM
A
airshot
reacted to
redneck joe's post
in the thread
Random
with
Like
Saturday at 2:58 PM
A
airshot
Saturday at 2:56 PM
P
pwilke
120hp Force year?
Thanks for the info., it's on a boat that I'm picking up tomorrow. It has a cracked water pump housing that I have to repair. I only...
Saturday at 2:51 PM
A
airshot
1978 Johnson 140hp running rough. Need advice
I would never use premium fuel if the mfgr recommends regular grade. Doing so can make your engine less powerful as premium fuel burns...
Saturday at 2:46 PM
redneck joe
Random
Saturday at 2:31 PM
ct1762@gmail.com
I would be planning on a rebuild as Racer said... 100-110psi is too low. those 78' 140's had very tight heads unless someone replaced...
Saturday at 2:12 PM
nola mike
reacted to
Grub54891's post
in the thread
Planning for spring tune up
with
Like
exactly, I’m used to the big water. You break down out there and you are miles from help, even with towboat insurance, bad weather will...
Saturday at 2:09 PM
redneck joe
posted the thread
a story i wrote today
in
Dockside Chat
I am not a writer or story teller, this just happened today. It is set sometime in the semi near future and is based on my reality and...
Saturday at 2:06 PM
ct1762@gmail.com
1988 Johnson 70hp - VRO or not to VRO?
the VRO/OMS pumps are extremely easy to test. you dont even need to remove it from the motor! Just need to remove the fuel out hose, and...
Saturday at 2:06 PM
