O
Open Water
replied to the thread
1988 Johnson 70hp - VRO or not to VRO?
2.6 oz of oil per gallon of gas. Peace of mind.
Sunday at 5:46 PM
O
Open Water
reacted to
rolmops's post
in the thread
with
Like
If anybody has any doubt left as to why Premixing is the better way to go... This might help: A lot of these VRO using engines blew up...
Sunday at 5:44 PM
Scott06
projects other than boats
Nice attched is my 65 GTO, second photo is the nee to me engine just had built for it. Hopefully going in the car over the next couple...
Sunday at 5:38 PM
P
Pvaughan23
Starting a 1974 Tri-Hull Restoration, it's a Stryker Mark IV model. Need help with any information or an owners manual.
It's registered and insured, and I'm licensed so after this weekend I'll have the batteries to test the outboard then I'll get some fall...
Sunday at 5:18 PM
twerth
Low Voltage at RPM?
Thanks for the quick replies! History: This is my second full summer with this boat. It's a 1991, but it has a 2001 engine. Presumably...
Sunday at 5:18 PM
roscoe
Transom saver or no?
Roads aren’t too bad around here, but I do 100-200 miles of washboard gravel in Canada every year. 15 mph would make sense, and 40...
Sunday at 5:16 PM
roscoe
reacted to
FLATHEAD's post
in the thread
with
Like
The roads here in my part of Pa. are pitiful. Transom saver all the way.
Sunday at 5:08 PM
tpenfield
Where are the shutoff valves?
The pump should prime itself from the water tank.
Sunday at 5:01 PM
B
BaltimoreSailor
Here's a pic of the pump. Up is up. It's mounted to an engine compartment bulkhead under the sink in the cockpit. Very difficult to...
Sunday at 4:57 PM
Seafoam vs. Marine Pro Seafoam
google snake oil
Sunday at 3:42 PM
R
Renken2000Classic
Epic launch
A friend's dad had one in a 1980 Chevrolet P/U. I was a little surprised they were still being used then. Prob bought up north...
Sunday at 3:27 PM
K
kenny nunez
OMC low profile stringer steering
There is a “O” ring that goes around the outer perimeter of the water pump housing that is to aid in keeping exhaust gasses from...
Sunday at 3:17 PM
Bt Doctur
Low Voltage at RPM?
losing voltage at rpm could indicate a winding opening up at high rpm inside the alternator
Sunday at 3:16 PM
C
cyclops222
reacted to
racerone's post
in the thread
with
Like
Oil that has been stored in the tank for a long time.-----Possible a wee bit of water mixed in with it due to condensation.----Oil tank...
Sunday at 3:15 PM
ESGWheel
Low Voltage at RPM?
If I may, suggest your priority is the bogging and running poorly at higher RPM. While you seemingly have a concurrent issue with...
Sunday at 3:13 PM
