Captain Caveman
replied to the thread
What kind of wrench (name) is he using in this video?
Agreed - it's a t-handled socket wrench. Clearly this guy has practiced his spinning technic for decades to achieve this level of spin...
Yesterday at 1:51 PM
A
airshot
reacted to
jimmbo's post
in the thread
85hp Merc?
with
Like
Rule of Thumb for years has been 1 mph for every 5hp Increase. I also factored that your 50hp was Crank Rated, and the 70hp was likely...
Captain Caveman
Seafoam vs. Marine Pro Seafoam
Since you didn't ask if Seafoam itself is worth the money, I'll leave that alone. If it is a product that works for you then by all...
Yesterday at 1:47 PM
I 2nd snake oil
Yesterday at 1:29 PM
Captain Caveman
Source for bearing buddies rubber plug
I got lost. Is this a thread about a source for BB caps, or a rant about proper bearing maintenance? :rolleyes:
Yesterday at 1:22 PM
Scott06
Source/question for a crossmember?
go to a welding shop for a custom one that fits, they can galvanize or as outlined cut a longer one and use the cold galvanizing...
Yesterday at 1:02 PM
C
cyclops222
Seafoam is a SLOW acting solvent. It does not suddenly dissolve all the crud at once and block tiny fuel passages. I use it 1 time...
T
tinkma
2003 Evinrude ficht stalls at medium speed
Sorry, we were just able to tend to the boat recently. We installed the EV diagnostic tool, but no codes were generated. We replaced the...
Yesterday at 12:59 PM
A
airshot
reacted to
racerone's post
in the thread
85hp Merc?
with
Like
The 2 strokes when maintained use a bit more fuel.----But they do not get sticker shock on repairs / maintenance at $125/hr or more...
J
JDusza
posted the thread
Johnson B-series Mystery Puking A Milkshake
in
Johnson & Evinrude Outboards
I have no model number. It is a straight 4, fuel injected 4-stroke from somewhere in the 2000s, supposedly 115 hp. The coin on the...
Yesterday at 12:50 PM
Need help: Bizarre Bravo III freshwater galvanic corrosion quandry
Not correct, different metals have different properties and do effect current
Yesterday at 12:36 PM
A
airshot
reacted to
mike_i's post
in the thread
Lowrance warranty
with
Like
Agree with Mc Tool, I was going to same the same thing. It may be a voltage issue. Confirm you have a good steady 12v supply.
Yesterday at 12:35 PM
reacted to
tpenfield's post
in the thread
projects other than boats
with
Like
I'm enjoying seeing folks projects. . . Here is my current project: Hardwood flooring. . . . . It has been about 25 years since I...
Yesterday at 12:34 PM
reacted to
Scott06's post
in the thread
with
Like
Nice attched is my 65 GTO, second photo is the nee to me engine just had built for it. Hopefully going in the car over the next couple...
Where are the shutoff valves?
^^^agree self prime The clear piece on the bottom is the filter. You can get rebuild kits for them and they are fairly easy to do
Yesterday at 12:33 PM
