C
cyclops222
reacted to
dingbat's post
in the thread
Lead acid battery. Two questions
with
Like
Are you sure about that? So, How Are Deep-Cycle Batteries Different? The thing that makes deep-cycle batteries "deep-cycle batteries"...
Yesterday at 5:20 PM
redneck joe
replied to the thread
Well crap, math...
Yesterday at 5:17 PM
R
87 50HP VRO Evinrude - Could this be my problem?
That pulse fitting is NOT USED on a regular fuel pump.----The regular fuel pump operates with PRESSURE and not vacuum.-----The regular...
Yesterday at 5:16 PM
redneck joe
Solar charging batteries
I used the plug in that came with it for 24 hours. I seemed to have e killed them.
Yesterday at 5:12 PM
redneck joe
I was just four months old
OK this was about star trek
redneck joe
reacted to
airshot's post
in the thread
Nobody fishing?
with
Like
Perch might be a boring fish to catch, but they are just so good to eat ! My family can't get enough of them. Here in the great lakes...
Yesterday at 5:11 PM
R
1988 Johnson 70hp - VRO or not to VRO?
Crankcase PRESSURE is what drives the simple pump.
Yesterday at 5:10 PM
dingbat
The grp. 27 deep cycle batteries I use for starting are rated at 109 amp hours each. Gives me 750 MCA (600 CCA) of starting current...
Yesterday at 5:05 PM
C
Crosbyman
2003 Evinrude ficht stalls at medium speed
see code 57 causing a shut down in th ETEC world. uncontrolled fuel relative to TPS position may be.... leaky VST vent valve...
Yesterday at 5:01 PM
A
airshot
Might not have a powerful enough solar panel to get that minimum needed voltage/ amps or what ever power they need.
Yesterday at 4:53 PM
C
cyclops222
reacted to
mr 88's post
in the thread
Planning for spring tune up
with
Like
Personally I would drop a electronic distributor in vs a Petronix set up , which also means a different coil . This will not fail you...
C
cyclops222
reacted to
Grub54891's post
in the thread
with
Like
exactly, I’m used to the big water. You break down out there and you are miles from help, even with towboat insurance, bad weather will...
Yesterday at 4:51 PM
F
FishAtFive
posted the thread
in
Johnson & Evinrude Outboards
I have an 87 50 HP Evinrude with the VRO system deleted by the previous owner. Been battling rough idle, and after running for awhile it...
A
airshot
We complain about our children watching the internet and their phones, while getting brainwashed.....so what is modern day TV doing to...
F
FishAtFive
reacted to
SparkieBoat's post
in the thread
Leaking VRO and hose
with
Like
Re: Leaking VRO and hose there is a pre mix fuel pump replacement that you can buy, it does not have the oil side..it is over $300...
Yesterday at 4:42 PM
