reacted to
nola mike's post
in the thread
Winterization difficulty
with
Like
You removed the engine but kept the drive on?
Nov 22, 2025
reacted to
Bondo's post
in the thread
with
Like
Ayuh,....... Welcome Aboard,..... You need to have the drive, Off, to put the motor back in, so do it now, then there's no...
Nov 22, 2025
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Assuming flat washers and lock nuts? Why fine thread, isn't it easier to over torque a bolt using fine?
Nov 22, 2025
tpenfield
Ribs, gussets, and bolts. . . .:unsure: While away, I did some detailed drawings of the extension pod and support structure. Yellow is...
Nov 22, 2025
C
My block is drained, right?
I generally use straight antifreeze, on the theory that it is diluted by whatever water is in the block. Of course, straight antifreeze...
Nov 22, 2025
reacted to
Scott Danforth's post
in the thread
with
Like
agree with above trying to swap a motor with the drive in is 5x as difficult than doing it with the drive off since you have to have...
Nov 22, 2025
reacted to
Lou C's post
in the thread
OMC 4.3 V6 dry joint "batwing" conversion exhaust kit
with
Like
I used one set of the Batwings from 2004-2011, at that point one of the 4 outlets was clogging with rust so I replaced them and ran the...
Nov 22, 2025
Lou C
Agreed, I would do that just to improve the odds so to speak. One nice thing about having the Sierra PG stuff and the refractometer, is...
Nov 22, 2025
Lou C
Nov 22, 2025
flashback
I think putting some AF in would be better even if it doesn't drain out, at least it might keep any water left from freezing.
Nov 22, 2025
redneck joe
reacted to
lgaytan's post
in the thread
View of unloaded trailer with pickups
with
Like
Ok I think I wouldn't mind to have rear cameras in my truck, I just tried a friends truck and that thing is amazing.
Nov 22, 2025
Nov 22, 2025
Nov 22, 2025
reacted to
nola mike's post
in the thread
with
Like
Well, gave it another shot today. Nothing. Probed, blew air in there, bow up/down. @Lou C , good thought, will do that next year @Scott...
Nov 22, 2025
Ayuh,...... I donno much 'bout the fitment being discussed here,.... But a couple of comments anyway,.. I can hardly believe Lou...
Nov 22, 2025
