tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
One thing about working with SS bolts is 'galling' , which can ruin your day. I had the issue with my extended swim platform build, so...
Nov 23, 2025
tpenfield
According to AI . . . "Coarse thread is more subject to loosening under vibration, while fine thread is less likely to loosen. This is...
Nov 23, 2025
F
froggy1150
reacted to
dwco5051's post
in the thread
Reminder to check gear before towing.
with
Like
I am from the generation where the kids piled in the bed of the pickup with the only safety warning "don't lean against the tailgate...
Nov 23, 2025
Lou C
Fuel starvation conundrum
I actually did the other day when I scoped the manifolds. Boat ran prefect with the outboard tank so I felt it had to be fuel related….
Nov 22, 2025
Grub54891
Random
https://www.roadsideamerica.com/tip/23790 then there is this too. I’ve personally been there and talked to the guy. I guess it’s his...
Nov 22, 2025
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
Nov 22, 2025
M
MikeSchinlaub
Redoing a Starcraft Islander transom using Coosa board.
3/4 is something like $400 per sheet, I can't imagine a 1.5in sheet. Or do you mean total laminate thickness? Anyway, some answers. I...
Nov 22, 2025
rolmops
It just occurred to me that you did not inspect the exhaust flaps.
Nov 22, 2025
tpenfield
reacted to
Pmt133's post
in the thread
with
Like
Better clamping
Nov 22, 2025
B
BOYS & TOYS
reacted to
66Holiday924's post
in the thread
1978 Islander 22 I/O
with
Like
Rebuilding the cuddy bench. They're not done, but you can see what it's going to be. I still have to revisit it and add a support...
Nov 22, 2025
P
Pmt133
Better clamping
Nov 22, 2025
F
four winns 214
Boats from work.
The flight in question was en route to Honolulu. None of the packages on that aircraft were destined for Continental U.S. addresses.
Nov 22, 2025
rolmops
posted the thread
in
Boat Restoration, Building, and Hull Repair
This summer I had my boat in a slip instead of always towing it and I love it. At the same time it made me anxious about humidity and...
Nov 22, 2025
TN-25
reacted to
Lou C's post
in the thread
My block is drained, right?
with
Like
I don't think this is your problem but some 4.3s like mine that originally came with the large Delco direct drive starter had a 90*...
Nov 22, 2025
nola mike
Point being there shouldn't be any water in the block, I'd rather know that than gamble on AF getting to where it's needed at the proper...
Nov 22, 2025
