aspeck
reacted to
redneck joe's post
in the thread
Boat values
with
Like
Had a old guy tell me once is the seller isn't pissed at you when money changes hands you paid too much.
Wednesday at 1:31 PM
A
airshot
replied to the thread
adding a forward fishing deck
Once you get it supported, my guess is the fiberglass would be heavier than the wood, and the wood will look better, and fit your needs...
Wednesday at 1:24 PM
aspeck
reacted to
redneck joe's post
in the thread
Offer accepted
with
Like
We'll start another thread for that if needed. There really isn't much to do at the house other than putting on the back deck off the...
Wednesday at 1:13 PM
D
DeepCMark58A
Pink Super Tech (Walmart) -50 RV and Marine ok for engine?? I always thought NO...??
I will stick to my Windsor engine and single screw over an outboard. People are intimated by having to work a rudder.
Wednesday at 1:11 PM
W
Wreck'D Hunter
1994 Evinrude 50 HP Not Charging
RR Part # 584476. Grounding appears to be solid. The red wire appears in good condition. RR grounding wire travels from the base of...
Wednesday at 1:08 PM
T
TnTommy
What prop to use 50hp evinrude
I think I’m gonna order a 11 5/8 x 12 prop, which is what Suzuki calls for and see how that one fits
Wednesday at 1:03 PM
C
Crosbyman
check RR part for OEM# .. 25VAC may turn out as a high DC if not regulated !! check for proper grounding of RR........... and...
Wednesday at 12:43 PM
FLATHEAD
Forest destruction
Of course you don’t see any mature trees. They are gone. The stumps remain. Many, many trees much bigger than 24 inch caliper in size...
Wednesday at 12:32 PM
W
Wreck'D Hunter
Test Complete - (relatively) steady 25 V AC across the 2 yellow leads (Wires 1&2 in the pic). For the test, I left them connected to...
Wednesday at 12:15 PM
D
DeepCMark58A
Boat is put away for winter. What to do every day ?
I had to saw up a branch that fell over the driveway in the snow storm, wife called me before I got my boots off about trees on the road...
Wednesday at 12:14 PM
B
Boaterdan278michigan
reacted to
tpenfield's post
in the thread
Boat values
with
Like
The graph tells me that there is a $7-8K increase per year in the average pricing. So, in terms of 'newness' and any desirable features...
Wednesday at 12:00 PM
B
reacted to
tpenfield's post
in the thread
Boat values
with
Like
Here is some Formula 34PC data . . . . . Formula prices are 30% higher than SeaRay, and keep in mind the at 20 years old brands may...
Wednesday at 11:59 AM
B
reacted to
redneck joe's post
in the thread
Boat values
with
Like
Wednesday at 11:27 AM
C
Crosbyman
1975 6 HP Johnson Shift rod is bent !!
i doubt the small bend is the problem... just make it straight if you think it is.
Wednesday at 11:23 AM
C
Crosbyman
in regards to 1.5v on the red ............ measure the AC signal across the yellows from the STATOR while running btw some of those...
Wednesday at 11:17 AM
