L
Lpgc
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
One thing that the N.A. was interested in reviewing, given the added buoyancy at the stern, was the trim angle of the hull. If the trim...
Feb 10, 2026
M
mauro.
replied to the thread
Boat value
Thanks for all the info I guess all I can do is try and see what I can get for it
Feb 10, 2026
tpenfield
Boat value
That strategy never really works . . . potential buyers will probably not care how much money you have invested in the boat. You should...
Feb 10, 2026
P
Pmt133
Mercury Tempest, Turning Point Mach 3 or Michigan Wheel Apollo?
I wouldn't commit to something I couldn't at least test but... all three are pretty solid choices. The tempest and Apollo are very...
Feb 10, 2026
Dukedog
Mercury V6 XR2 - Does this Stator looks bad?
you are describing exactly tha way some act straight outta tha box from merc with tha way it cools.. we called it "consumer R&D"...
Feb 10, 2026
R
rjcamel2355
99 3.1l ox66 wont rev (what am i not thinking of here)
It's a 1999 3.1L 200hp V200TLRX if that makes any difference. 1- Doesn't limit RPM in neutral (will rev in neutral, and in reverse)...
Feb 10, 2026
JeepGuy319
posted the thread
Starts right up sometimes, but other times crank no start
in
Johnson & Evinrude Outboards
Hi everyone, I am new to boats and 2 stroke motors, but I do have mechanical experience working on cars and small engines. Anyway, I...
Feb 10, 2026
P
Pmt133
2000’s Bayliner 175 I/O
I think the wood free models were later. That being said... they are "cheap" in the sense that when new they were ~10k new if memory...
Feb 10, 2026
matt167
posted the thread
in
Boat Topics and Questions (not engine topics)
I didn’t get out boating last year. Never worked on my big StarCraft and never got the little one out even once. The big StarCraft...
Feb 10, 2026
M
mauro.
Boat value
too bad when you think I have over 7k in receipts from this fall😒
Feb 10, 2026
J
jlh3rd
I prop for the higher end of the manufacturer's recommended max rpm @WOT for the longevity of my engine. Everything else becomes what...
Feb 10, 2026
M
MikeSchinlaub
reacted to
tphoyt's post
in the thread
Boats from work.
with
Like
Right I mean there is a trash can right next to the toilet. I have my suspect in mind but a few people wear them so everyone was warned...
Feb 10, 2026
C
posted the thread
in
Prop Questions and Topics
All, I am considering the title, three props, all in 3 blade and 21" pitch for my speedboat. My speedboat is an old Avenger, 16 footer...
Feb 10, 2026
C
2002 Johnson 150 (Carb) Oiler Delete
Gee, the standard oil reservoir in that motor is good for at least 75 gallons of fuel. I fill the oil reservoir each time I fill the...
Feb 10, 2026
C
Crosbyman
posted the thread
Needs some volts and amps for your 24 trolling kicker ?
in
this little $20 module should supply a 24v from your 12v battery if you mostly slow troll. it can give you 15- 20 amps and no...
Feb 10, 2026
