Cuppy420
reacted to
Scott Danforth's post
in the thread
Triton 175 rear deck removal
with
Like
if the screw is 18-8 (most likely), they are mildly magnetic. you can use a cheap $2 stud finder (the cheesy ones with the swinging magnet)
Feb 11, 2026
Cuppy420
reacted to
MikeSchinlaub's post
in the thread
with
Like
Lift up and get a feel for where it's held down, then poke around with a pick for an eternity until you find it. Since you're...
Feb 11, 2026
replied to the thread
Feb 11, 2026
M
Mc Tool
reacted to
99yam40's post
in the thread
99 3.1l ox66 wont rev (what am i not thinking of here)
with
Like
hard to believe one cylinder would cause that much difference, but who knows for sure. I am not sure what a non-functioning Knock sensor...
Feb 11, 2026
southkogs
2000’s Bayliner 175 I/O
In '02 they weren't wood free. But I know that the construction methods had improved by then. My 02 started life as a dock boat up in...
Feb 11, 2026
M
MikeSchinlaub
Boats from work.
Doing the flake on the Ranger now. This time, instead of blacking out the bodywork under each color as I go, I gelled the whole spot...
Feb 11, 2026
M
MikeSchinlaub
Feb 11, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
1 transom cavity filled with 1" of fiberglass . . . 1 more to go. 22 total layers of 1708,1808, CSM combination . . . 1 gallon of...
Feb 11, 2026
tpenfield
Feb 11, 2026
B
bakerjw
reacted to
in the thread
with
Like
replace all the plastic thru-hulls if you get it, they will fail soon.
Feb 11, 2026
Cuppy420
That's what i'm thinking it's just a missed screw or two. I just don't know how to access them or find them
Feb 11, 2026
Cuppy420
reacted to
in the thread
with
Like
If you're on android, look at the top right of your camera screen. It probably says 64M, tap it and it will change to 12M. It's the...
Feb 11, 2026
M
MikeSchinlaub
Feb 11, 2026
Cuppy420
Yes, there are 2 bars going across. But the deck is loose from that as I took the pedestal off
Feb 11, 2026
Cuppy420
It says my file is too large to post a pic. Yes, i've gotten all of the screws off of the deck.
Feb 11, 2026
