Captndrydock
reacted to
Nordin's post
in the thread
Wiring a 3 wire trim/tilt pump to throttle handle switch
with
Like
The relays can handle the current that the electric pump motor need to operate. As I am in Sweden Europe we use square millimeter when...
Feb 12, 2026
C
Crosbyman
replied to the thread
1977 70 hp johnson thermostat housing gasket
Dry fit should do.. we are talking water not fuel. At worst even a small drip will probably close up after a while due to mineral build...
Feb 12, 2026
DWbaseball
StarCraft Splash of the Year 2025 - Nominations
Yea I would like to be able to pass on the StarCraft OTY honors but it didn't seem like we had lots of splashes to me either. There was...
Feb 12, 2026
R
rodsnguns
They appear to be. I will probably apply a very thin film on the Gasket, not even enough to ooze out.
Feb 12, 2026
R
rodsnguns
Yep I think I have the grommets too. I would probably just put a very thin film of sealer on both sides of Gasket, hardly enough to...
Feb 12, 2026
flashback
I/O (Sterndrive) Conversion to Outboards
1600+ hp, that would be sweet!
Feb 12, 2026
flashback
reacted to
Pmt133's post
in the thread
with
Like
Yeah... but I'd still want twins. :LOL:
Feb 12, 2026
P
Pmt133
Feb 12, 2026
P
PSmolchek
posted the thread
2003 150 Sport - Old DECALS / STICKERS?
in
Boston Whaler
MORNING! New BW owner - came with a house I purchased. 2003 BW 150 Sport - great little boat. She runs and works perfectly fine, just...
Feb 12, 2026
S
saltchuckmatt
reacted to
racerone's post
in the thread
with
Like
Also replace the 2 rubber grommets in there.---A very thin coat of a gasket sealer ( Permatex ) is all that is required.----Many folks...
Feb 12, 2026
S
saltchuckmatt
I just do it dry. Mating surfaces good?
Feb 12, 2026
R
Feb 12, 2026
R
The " UP " operation requires more current.----More work is being done.
Feb 12, 2026
jerryjerry05
Depending on how far the wires are ran?? you could use 12g. wire but the 10g would be the best. When they started using the relays, I...
Feb 12, 2026
jerryjerry05
reacted to
Captndrydock's post
in the thread
with
Like
Thanks Nordin! For now, I think I'll just use the 10 ga cable, I see no reason to add relays or solenoid, just to run a smaller wire. Is...
Feb 12, 2026
