R
rodsnguns
replied to the thread
1977 70 hp johnson thermostat housing gasket
Plenty confident. I just dont like to have to go back and do something twice or half way. I was looking for a kit but couldn't find one...
Feb 13, 2026
Can't slide the remote into forward gear.
Ayuh,.... No, it shouldn't matter,.... So the upper is still on the boat,..?? Have you inspected where the upper, 'n lower join...
Feb 13, 2026
P
Pmt133
reacted to
bakerjw's post
in the thread
Thinking about making a trailer cover... Opinions wanted.
with
Like
I also sew a lot of things from clothes for my granddaughter to curtains to long distance bicycling bags to pillows and more. If we want...
Feb 13, 2026
B
bakerjw
1981 Springbok 18' Restoration/Renovation
I am envious. Aluminum doesn't make you itch.
Feb 13, 2026
dingbat
Nobody fishing?
Add another half dozen rods, a pair of planer boards and two gps units and you’ve almost caught up with me…. Lol Glad things worked...
Feb 13, 2026
B
bakerjw
reacted to
Pmt133's post
in the thread
with
Like
So it's not a matter of knowing that I can do it... I can. I think it's more if it's worth the resources and time. The goal: Build a...
Feb 13, 2026
B
bakerjw
reacted to
Earl Cordova's post
in the thread
with
Like
Don't know how good your sewing skills are, but mine are not good so I would pay a pro to do the work. Otherwise I would cringe...
Feb 13, 2026
B
bakerjw
Feb 13, 2026
B
bakerjw
reacted to
redneck joe's post
in the thread
1994 Starcraft Super Fisherman 170 Rebuild Help
with
Like
The overarching key here is if yer gonna do it, now is the time to do it right. Listen to others that are smarter than you and if you...
Feb 13, 2026
B
bakerjw
reacted to
Cuppy420's post
in the thread
Triton 175 rear deck removal
with
Like
I got it out!! I found a screw on either side hidden by carpet! I used a magnet and it found them! Thanks everyone for your help!
Feb 13, 2026
L
Lpgc
reacted to
Scott Danforth's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Ted, how many cases of beer will fit in the bilge where the two 6.2's used to sit? Did you figure in the weight of "provisionings" in...
Feb 13, 2026
R
can you remove the top drain plug screw from a lower unit and re instal it with a new washer ?
????-----Are you checking if there is 50% water in it , yes or no ?
Feb 13, 2026
roscoe
reacted to
Evinrudej's post
in the thread
with
Like
Ok thanks I just wanted to double check. I just checked a lower unit from the top drain plug screw to see if it had gear oil inside...
Feb 13, 2026
N
Nordin
1991 150B force outboard no spark
No upgrade system as I know. The Thunderbolt system that Mercury used on the Mercury brand was the last system on Force 150 5 cyl...
Feb 12, 2026
E
Evinrudej
Feb 12, 2026
