dingbat
replied to the thread
67 Year Old Head Bolts
Funny in that all my years in welding and machine work, I don’t think I’ve ever heated aluminum to do anything other than preheat large...
Feb 14, 2026
jerryjerry05
Wiring a 3 wire trim/tilt pump to throttle handle switch
It works harder going up, more strain as you trim it up. Going down is easier on the system. The 3 wire motors basically the same as...
Feb 14, 2026
rolmops
reacted to
Lou C's post
in the thread
Thinking about making a trailer cover... Opinions wanted.
with
Like
Don’t forget when you eventually sell, anything that’s not in compliance can hold up the deal…
Feb 14, 2026
R
rodsnguns
1977 70 hp johnson thermostat housing gasket
Same here salt. I have some of my most intelligent conversations when I am by myself. And the answers are almost always what I want to...
Feb 14, 2026
matt167
2000’s Bayliner 175 I/O
There is a 1978 Sylvan Sportster 18 listed for $6,200 that looks like it’s in great shape. It would be a very close cousin to my...
Feb 14, 2026
S
Steve51
Calorifier question?
Hi Thank you for the responses... It is the SeaCore Version. The kit has 3 straight connectors but it is for a variety of Mercruiser...
Feb 14, 2026
tpenfield
Here is a picture . . . not the easiest thing to see. The lower hose is on the re-circulating pump and the upper hose is on the...
Feb 14, 2026
reacted to
tpenfield's post
in the thread
with
Like
Calorifier . . . That's a new term for me . . . basically a domestic water heater on a boat. (right)? I happen to have 2 Mercruiser...
Feb 14, 2026
tpenfield
Feb 14, 2026
Lou C
Feb 14, 2026
S
Steve51
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Hi, I have a brand new Mercruiser 6.2L 350HP V8 recently installed with a Bravo3 Sterndrive. Does anyone have a picture of the engine...
Feb 14, 2026
S
saltchuckmatt
Yeah colored crayons discolor the paint for sure, I just use light or dark depending on the motor so white on white and the darker on...
Feb 13, 2026
M
Mc Tool
I think that the ally conducts heat away so fast that it can soak up a far bit of heat ,and I think you gain more by heating moderately...
Feb 13, 2026
S
saltchuckmatt
I use map gas and go forever....sometimes the original OMC paint doesn't even show much harm amazing stuff. Acetylene, map gas I've...
Feb 13, 2026
S
saltchuckmatt
reacted to
dingbat's post
in the thread
with
Like
Aluminum doesn't change color when heated. The first indication that your too hot (~660 C) is when the over heated area drips to the floor
Feb 13, 2026
