R
rodsnguns
posted the thread
Lubricate new water impeller rubber ?
in
Johnson & Evinrude Outboards
I have seen various methods people use when replacing the water impeller in an older Johnson 60-70hp. Some say they like to apply a...
Feb 16, 2026
tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Yes, excited about the budget fix . . . I also saved $1,900 by ordering silver instead of white.
Feb 16, 2026
tpenfield
To get 350 HP, you have to go to the V10 . . . Top of the V8 line (600 ish lbs) is 300 HP.
Feb 16, 2026
tpenfield
Yes, there is about 2,000 lbs of buoyancy in the extension-bracket. Per the analysis the N.A. did, the hull sits with a very slight...
Feb 16, 2026
reacted to
muc's post
in the thread
Twin Merc 250 fuel burn difference's
with
Like
This can be a tough one to get a dealer to spend the needed time on. This needs to be diagnosed while out on the water under load. Need...
Feb 16, 2026
M
muc
Feb 16, 2026
WIMUSKY
2026 NFL/CFB News and Nonsense
https://www.facebook.com/share/r/1LUevkerRc/
Feb 16, 2026
T
tphoyt
Being back on budget must feel real nice. I can’t say I have ever heard anyone say anything bad about Hondas. I had a 15 back in the...
Feb 16, 2026
Great to see you back again The reason for the post is this is pretty close to what I was seeing with the starboard motor. The...
Feb 16, 2026
M
muc
Warning horn not getting ground
Hi @Jeanric Is this something you're still working on? If so I might be able to help. The Ford ECA (what you are calling ECU) doesn't...
Feb 16, 2026
M
muc
Hi, been away. I can't really tell much from the vid. A scan tool might say more. It's been a decade since I was last in the boat...
Feb 16, 2026
so...... you have to leave 1 case of beer behind? or did you account for that in the buoyancy calculations
Feb 16, 2026
dingbat
reacted to
tpenfield's post
in the thread
with
Like
This is what's happening for the engines . . . . . Honda BF350's AUDA/AUCDA Optimus 360 Joystick system They are big, but rarely...
Feb 16, 2026
So decided to go with the weight equivalent of the V10 instead of V8
Feb 16, 2026
Lou C
Interesting, so about the same weight as (engine alone) a Mercruiser V8, but then you have to add the transom mount/outdrive and you...
Feb 16, 2026
