Captndrydock
replied to the thread
Wiring a 3 wire trim/tilt pump to throttle handle switch
Makes sense. I'm trying to figure out what solenoids to buy at the moment. Still looking for a parts blow up with oem parts to match...
Feb 18, 2026
Captndrydock
reacted to
jerryjerry05's post
in the thread
with
Like
It works harder going up, more strain as you trim it up. Going down is easier on the system. The 3 wire motors basically the same as...
Feb 18, 2026
Bt Doctur
looking for recommendations for gimbal bearing puller
same one here ,great tool
Feb 18, 2026
L
Lpgc
reacted to
MikeSchinlaub's post
in the thread
Random
with
Like
Feb 18, 2026
P
Pmt133
I/O (Sterndrive) Conversion to Outboards
I like the foam. When I did my stringers and deck I just tabbed them in in one shot when the edge was bedded in PB so it was a wet tab...
Feb 18, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
The Honda BF350 'U' (30") shaft motors weigh about 775 lbs. :oops: My design calculations were based on 700 lbs/engine. Out of...
Feb 18, 2026
Texasmark
Mercury Tempest, Turning Point Mach 3 or Michigan Wheel Apollo?
Considered Ballistic props? Their SS blades have a lot of Rake and squared off, cupped tips on the blades. Lot of design there to get...
Feb 18, 2026
E
Earl Cordova
reacted to
in the thread
Random
with
Like
Feb 18, 2026
T
tphoyt
I’m sure the foam was a time saver. That worked out well.
Feb 18, 2026
matt167
posted the thread
2020 DF35A 30hp conversion.
in
Yamaha & Suzuki Outboards
I’ve decided that I’ll just run my little boat this year and possibly spend a couple of weekends on the big boat and see if I can get it...
Feb 18, 2026
tpenfield
Feb 18, 2026
jimmbo
reacted to
racerone's post
in the thread
Lubricate new water impeller rubber ?
with
Like
A dry impeller will be submerged in water as soon as boat is launched.----There will never be any immediate damage to a properly fitted...
Feb 17, 2026
A
airshot
reacted to
Pmt133's post
in the thread
Been a little cold.
with
Like
Jersey. But after sitting around 10 for 3 weeks it feels lovely. :ROFLMAO:
Feb 17, 2026
A
airshot
LiFePO Batteries ???
I also Put my look battery in the house for the winter. TimeUSB recommended cycling the battery every three months while not being...
Feb 17, 2026
flyingscott
reacted to
Scott Danforth's post
in the thread
with
Like
KY jelly works as a great impeller lube because it's water soluble
Feb 17, 2026
