C
Crosbyman
replied to the thread
67 Year Old Head Bolts
carbon build up...
Feb 22, 2026
flashback
Trailering Rule # 1
couple of bad days there.
Feb 22, 2026
flashback
reacted to
Fun Times's post
in the thread
Trailering Rule # 1
with
Like
#2 could be proper fueling,:oops: https://www.instagram.com/reel/DUjk2W7EaeF/
Feb 22, 2026
flashback
reacted to
roscoe's post
in the thread
Trailering Rule # 1
with
Like
https://www.facebook.com/reel/1908417733085196
Feb 22, 2026
M
MikeSchinlaub
1969 StarCraft Transom
Plywood will last a long time if sealed properly, either csm and polyester resin or Old Timer's Formula ( a sealant the woodworking guys...
Feb 22, 2026
frustratedboater
04 Yamaha 225 4-stroke- -injector harness 2 End Plugs?
Thank you.
Feb 22, 2026
C
Crosbyman
trying to install a pre-owned PTT to a1996 Johnson 50
basically any single pole double throw switch should do if powering the low power needs of the transfer solenoid's coils . +12v...
Feb 22, 2026
P
Pmt133
Finally. Some warm times.
My commute home tonight is going to suck a little extra I think. :LOL:
Feb 22, 2026
P
Pmt133
reacted to
Chris1956's post
in the thread
with
Like
The forecast is for 24" of snow here at the Jersey shore. If course, that presupposes the temp drops at the right time. If not, maybe...
Feb 22, 2026
kbh121956
Thank you for the reply.
Feb 22, 2026
B
bakerjw
reacted to
alldodge's post
in the thread
with
Like
Yesterday morning not bad Buddy came over and had the shop overhead door open and having a couple beers around 1PM (60*). By 2:30 temps...
Feb 22, 2026
matt167
Originally many of the small StarCraft and other tin boats had a small plywood section under the motor. It doesn’t really need to be...
Feb 22, 2026
kbh121956
posted the thread
in
Boat Restoration, Building, and Hull Repair
Hello, what is a good product for the outside transom on an aluminum StarCraft? Does it need to be a thin plywood or something else that...
Feb 22, 2026
C
Feb 22, 2026
R
2020 DF35A 30hp conversion.
Weight up front generally means a loss of speed.
Feb 22, 2026
