FLATHEAD
replied to the thread
SNOW Common Sense
Hang on to your hat!! Same system has just wound down here for the most part. Got a little over 8 inches of snow out of it.
Feb 23, 2026
tpenfield
SNOW Common Sense
We are in the thick of it , , , probably 8-10 more hours. Winds are 30 sustained, gusts to 58 mph. The outer Cape (Chatham) has 50...
Feb 23, 2026
B
Boaterdan278michigan
1994 5L EFI Volvo penta
I'll take pics as soon as I can get back to the storage facility. It's not stored at home.
Feb 23, 2026
B
reacted to
alldodge's post
in the thread
with
Like
I don't know which starter you have, but if it has more than one main Battery cable connection, than you should be able to jump from the...
Feb 23, 2026
P
Pmt133
SNOW Common Sense
I'm not going anywhere unless I have to. :LOL:
Feb 23, 2026
Bob_VT
SNOW Common Sense
ALL three vehicles are 4WD qne so is my Polaris......... when all else fails I can park at the farm next door and walk up. I have all...
Feb 23, 2026
E
Evinrudej
can you remove the top drain plug screw from a lower unit and re instal it with a new washer ?
Yeah I doubt it too. Washers would have to be complete junk. Well that gives me better peace of mind
Feb 23, 2026
E
Evinrudej
reacted to
racerone's post
in the thread
with
Like
I doubt that rain water can get in , even with used washers !
Feb 23, 2026
R
Feb 23, 2026
FLATHEAD
Trail camera issues fixed, now pics from them ...
Deer aren’t happy. More snow!
Feb 23, 2026
E
Evinrudej
reacted to
Earl Cordova's post
in the thread
Quick silver 90w gear oil okay for 60hp
with
Like
Very little difference between 80w-90 and 90w, so why not ?
Feb 23, 2026
E
Evinrudej
Seems as thought they definitely learned something makes much more sense to run gear oil in a front axel rather than hydraulic fluid. I...
Feb 23, 2026
E
Evinrudej
I appreciate the information. I’ve done many lower unit oil changes always with the outboard vertical and always replace my drain plug...
Feb 23, 2026
S
saltchuckmatt
trying to install a pre-owned PTT to a1996 Johnson 50
You can just buy the handle trim assembly online or used. There's plenty out there or go to one on the dash. I've always gone with the...
Feb 23, 2026
A
AusFox
Mercruiser 350 MAG MPI
Thanks alldoge, The boat is an 80's caribbean and I understand the engine components to all be from around the 2008 time frame. I...
Feb 22, 2026
