A
airshot
replied to the thread
Lowe 185 Ski & Fish with Verado 150 – bow won’t lift
I have used this setup for 60 years and it has always worked well. Trim the motor until the cav plate is parallel the the hull. Use a...
Feb 23, 2026
tpenfield
SNOW Common Sense
Power went out around 9:30 am. 😝
Feb 23, 2026
Pro XS 115 weight 163kg (359lb) Verado 150 weight 231kg (509lb) Pro XS 150 weight 207kg (456lb) The vids on line do not have anyone on...
Feb 23, 2026
S
Smgvh
posted the thread
in
Boat Topics and Questions (not engine topics)
◆Boat Setup & Test Summary for Lowe Boat ◇Boat Information Model: Lowe 185 (Not sure model year exactly but around 2007) Serial No...
Feb 23, 2026
WIMUSKY
reacted to
FLATHEAD's post
in the thread
Trail camera issues fixed, now pics from them ...
with
Like
Deer aren’t happy. More snow!
Feb 23, 2026
R
Mercury V6 XR2 - Does this Stator looks bad?
Every outboard cylinder head I look at is warped !----Just the nature of aluminum castings.----Resurface it and test run.
Feb 23, 2026
Lou C
Electronic steering
If you're in fresh water and trailer the boat, leave it as an I/O. Outboards are great when new and are low maintenance and better...
Feb 23, 2026
dwco5051
reacted to
WIMUSKY's post
in the thread
Random
with
Like
Feb 23, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
BTW - with all that glassing of the core sections, the transom was H-E-A-V-Y .. . . I had to put my beer down to get it into place...
Feb 23, 2026
Lou C
Which exhaust manifold gasket?
pic of inside of the elbow/manifold joint
Feb 23, 2026
Lou C
I'd say you were VERY LUCKY that those didn't leak on the inside like they did on the outside! Agreed, I'd use Fel/Pro for your...
Feb 23, 2026
dingbat
Electronic steering
Have never had the need to go to some sort of “assisted” steering Still using the OEM NFB helm with the original cable on the boat...
Feb 23, 2026
C
Gee, that top combustion chamber on the cylinder head is steam cleaned enough to eat off.
Feb 23, 2026
Electronic steering
My boat (OB) has electric/hydraulic steering. Has a electric motor turning a hydraulic pump, if E-motor stops it gets extremely hard to...
Feb 23, 2026
Electronic steering
sell your I/O boat, buy an outboard boat
Feb 23, 2026
