replied to the thread
Looking for alignment tools
Search using goggle
Feb 23, 2026
1994 5L EFI Volvo penta
If key switch doesn't work it can be Ignition fuse blew Key switch went bad Neutral safety switch is bad or throttle handle is not in...
Feb 23, 2026
A
airshot
That was about 10 years back, but have talked to others that still find them on EBay recently
Feb 23, 2026
G
Garutlan
posted the thread
1999 Volvo Penta 5.0 GL freeze plug kits
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Anyone know a part number for a freeze plug kit for the engine in the thread title. Was not sure if a GM cross reference would work...
Feb 23, 2026
A
airshot
reacted to
Lou C's post
in the thread
SNOW Common Sense
with
Like
Same mines been on the same roller trailer since I’ve owned it, I did add some rollers to spread the load out better but it’s been fine.
Feb 23, 2026
A
airshot
reacted to
Pmt133's post
in the thread
SNOW Common Sense
with
Like
I usually am more concerned for the cover. So I waded out waist deep and brushed mine off. :)
Feb 23, 2026
A
airshot
Been a little cold.
I have always wanted a summer place in the UP of Mich, then a winter place in the south, so I could keep from freezing in winter and out...
Feb 23, 2026
A
airshot
reacted to
Pmt133's post
in the thread
Been a little cold.
with
Like
You just need to find more creative activities to do.
Feb 23, 2026
A
airshot
Lowe 185 Ski & Fish with Verado 150 – bow won’t lift
Move some weight out off the bow, check for water live free foam in the bow. Is there a hook or a curve in the keel ? Cab plate looks...
Feb 23, 2026
B
Boaterdan278michigan
I pulled my start battery and had it tested. It tested good. It's just damn odd that both starters (engines) don't respond to the key...
Feb 23, 2026
Ifishmuskie2
What is the aluminum repair on the left side stern?
Feb 23, 2026
A
AusFox
Mercruiser 350 MAG MPI
Thanks, I have found the crank position sensors brass threaded insert to be a bit loose so I have removed that and going to put some...
Feb 23, 2026
R
Mercury V6 XR2 - Does this Stator looks bad?
Why did they laugh?----If it was warped , how much was it warped?
Feb 23, 2026
Best "free" fish scanning and verifying/regulation app?
What about take a pic of the fish and let google tell ya what it is. It will at least get you close
Feb 23, 2026
M
MikeSchinlaub
1981 Springbok 18' Restoration/Renovation
Cowards!
Feb 23, 2026
