reacted to
Bondo's post
in the thread
5.x GX Parts Issues
with
Like
Not necessarily,..... Sun rots rubber, motors rarely see sunlight,..... Unless yer seeing cracking, or rot, they'll probably be...
Feb 25, 2026
replied to the thread
5.x GX Parts Issues
I found that for all except the pump suction tubes, you can go here...
Feb 25, 2026
1999 Volvo Penta 5.0 GL freeze plug kits
Remember, the block water jacket should hold 15psi. the points of failure if it froze will be both exhaust manifolds will have a crack...
Feb 25, 2026
ratdude747
When boating, always ___________________
My boat is grandfathered (1976 Starcraft Montego). The helm is somewhat crowded-in at least. Wouldn't be hard to retrofit (ground the...
Feb 25, 2026
dingbat
Electronic steering
Using a lower durometer ring might help, but saltwater would eat them alive in their role as a rod wiper. Really need end caps with...
Feb 25, 2026
ratdude747
reacted to
Pmt133's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Hey Ted, if it sways you any... I just got back from the boatshow and they had a new Suzuki 300 that was leaking oil from the gear case...
Feb 25, 2026
K
Kosmofreeze
reacted to
Bondo's post
in the thread
5.x GX Parts Issues
with
Like
Feb 25, 2026
G
Garutlan
Understood- I am going to inspect this weekend- with nicer weather. Thanks-Geoff
Feb 25, 2026
5.x GX Parts Issues
Feb 25, 2026
R
rodsnguns
Old humminbird dial flasher inline fuse specs
Yea I have seen some very inexpensive modern day units out there. Just not my thing, yet. I grew up with the old lowrance eagle and...
Feb 25, 2026
reacted to
flashback's post
in the thread
with
Like
Think of it this way, pot life of resin will be longer, enabling longer working time, everything thing will be waiting for the power to...
Feb 25, 2026
you realize that for under $50 you can get a much much better unit than the old hummingbird flashers look up kayak fish finder on...
Feb 25, 2026
flashback
Feb 25, 2026
K
Kosmofreeze
posted the thread
5.x GX Parts Issues
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Anyone having problems sourcing the rubber pre-formed hoses for the early 2000 Volvo Penta 5.x GXx? All of my regular on-line VP parts...
Feb 25, 2026
R
rodsnguns
Thanks Scott. My old brain cells were leaning toward the way back when memory of it being a 1 amper. Just wasnt sure. I will go with...
Feb 25, 2026
