B
Boaterdan278michigan
replied to the thread
1994 5L EFI Volvo penta
Thanks to all of you who provided suggestions. Interestingly I pulled my start battery and had it tested. I didn't recharge it, just...
Feb 26, 2026
tpenfield
I/O (Sterndrive) Conversion to Outboards
Quick Update . . . It seems like emergency preparedness is not a thing where I live. I know the severity of the weather has been a...
Feb 26, 2026
tpenfield
reacted to
aspeck's post
in the thread
with
Like
Aren’t you glad we are all here to help out and support?!?! With friends like us … you better have good insurance!:whistle:
Feb 26, 2026
B
Feb 26, 2026
B
reacted to
Horigan's post
in the thread
with
Like
In the future, just pull the fuel relay(s) for compression tests. I believe that’s what the manual has you do.
Feb 26, 2026
B
reacted to
muc's post
in the thread
with
Like
Some boat manufactures wired the emergency tether (kill switch) into the purple wire. So in some twins you will loose both engines when...
Feb 26, 2026
aspeck
Feb 26, 2026
Horigan
Warning horn not getting ground
Along those lines, I don’t get a warning horn when the oil or water switches are activated, but the SLOW system does engage.
Feb 26, 2026
Horigan
Feb 26, 2026
dwco5051
reacted to
rodsnguns's post
in the thread
Old humminbird dial flasher inline fuse specs
with
Like
Yea I have seen some very inexpensive modern day units out there. Just not my thing, yet. I grew up with the old lowrance eagle and...
Feb 25, 2026
D
DeepCMark58A
New project
I will use it on the lake I live on only so it is going to be used for crappie and you fish crappie after dark here because the water is...
Feb 25, 2026
tpenfield
reacted to
Scott Danforth's post
in the thread
with
Like
Ted, if need be, I can tell you how to mix acetone and engine oil to run thru the oil burner. you will need to watch the exit temps.
Feb 25, 2026
tpenfield
reacted to
aspeck's post
in the thread
with
Like
Build a fire on the floor of your garage ... what could possibly go wrong?!?!:oops:
Feb 25, 2026
Lou C
99 Volvo 5.0GL
Did you pull out the fuel pick up tube and see if there's a clogged screen on the end of it? What can happen is this: some of these pick...
Feb 25, 2026
R
Throttle lever assembly pin
The missing pin is part of that vertical lever assembly.-----And they are proud of it judging by how many beer tokens they want for...
Feb 25, 2026
