tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Internet is back . . . firing on all cylinders (almost) . . . I'm just about to run out of heating oil and based on my call to the...
Feb 27, 2026
tpenfield
reacted to
Scott Danforth's post
in the thread
with
Like
So, Ted, how was the pizza and beer by the fire?
Feb 27, 2026
tpenfield
SNOW Common Sense
Some quick math says I have about 4,000 lbs of snow (water) on my boat . . . figuring from the several storms I have the equivalent of...
Feb 27, 2026
Lou C
SNOW Common Sense
I think extra weight from a static load (boat sitting with snow on the cover) is way different than a dynamic load (boat bouncing down...
Feb 27, 2026
Lou C
Electronic steering
Agreed. I still haven’t given up my points ignition lol. Luddite-ism is hard to shake! I thought of getting the Delco EST and then had...
Feb 27, 2026
Texasmark
Electronic steering
Noticed how many "new??" companies are getting into the auto repair insuring business. They use that logo "remember, everything...
Feb 27, 2026
Grub54891
reacted to
Bondo's post
in the thread
Proper Oil For Oil Bath Hubs
with
Like
Ayuh,...... I use the same oil as I use in the outdrive,.....
Feb 27, 2026
J
JonBoat55
reacted to
Pmt133's post
in the thread
SNOW Common Sense
with
Like
I'm not going anywhere unless I have to. :LOL:
Feb 27, 2026
K
KJM
SNOW Common Sense
Everything is solid under the floor. I redid it all a few years ago. Oh well, spring will tell the tale. Kinda wouldn't mind a new boat...
Feb 27, 2026
K
KJM
reacted to
airshot's post
in the thread
SNOW Common Sense
with
Like
If you're he hull and super structure are solid then no way would it cause an issue. However, if the wooden structure is rotten then...
Feb 27, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
The power came back on last night . . . not sure what time. the internet is still down, so I am using my phone as a hot spot. (only 2...
Feb 27, 2026
J
jlh3rd
reacted to
airshot's post
in the thread
When boating, always ___________________
with
Like
Do I recomend the lanyard...YES....do I always use it...no...yes I should and try to remember but often get to my fishing spot before I...
Feb 27, 2026
Ifishmuskie2
reacted to
roscoe's post
in the thread
One fuel line to two engines
with
Like
I have been running a water sep filter with 2 outlets. A primer bulb on both, going to a 115hp and a 15hp outboard. Have never had one...
Feb 27, 2026
Feb 27, 2026
T
tphoyt
reacted to
tpenfield's post
in the thread
with
Like
Feb 27, 2026
