J
janul15
replied to the thread
Check/Fix/Replace Starter Motor 1996 50hp
This is what I can give you. Engine is not new to me. Was running last summer on muffs. Found a serious hole in the boat's hull, so...
Mar 2, 2026
redneck joe
Getting impatient
Well I did just make a huge pot of my famous bean and bacon soup...
Mar 2, 2026
L
Lpgc
When boating, always ___________________
I electrically disconnected my lanyard switch because it's broken, the engine ignition wiring (purple wire) was routed through it but it...
Mar 2, 2026
B
BOYS & TOYS
reacted to
DWbaseball's post
in the thread
StarCraft Splash of the Year 2025 - Nominations
with
Like
It seems like there will be no StarCraft of the year for 2025. Mods can close the thread. Hopefully we will see some worthy StarCraft...
Mar 1, 2026
G
Garutlan
reacted to
Scott Danforth's post
in the thread
1999 Volvo Penta 5.0 GL freeze plug kits
with
Like
Remember, the block water jacket should hold 15psi. the points of failure if it froze will be both exhaust manifolds will have a crack...
Mar 1, 2026
A
AusFox
Mercruiser 350 MAG MPI
Yes mate that is the sensor I have and removed.
Mar 1, 2026
dingbat
reacted to
bakerjw's post
in the thread
with
Like
My ETec will also run if the kill switch clip is not in place.
Mar 1, 2026
P
Pmt133
reacted to
matt167's post
in the thread
2000’s Bayliner 175 I/O
with
Like
It’s got a 9.9 kicker with remote steering, a Hilux 7 and a Lawrence GPS plotter fish finder…. But even if it’s a good deal I’m going to...
Mar 1, 2026
B
bakerjw
reacted to
MikeSchinlaub's post
in the thread
Filling a gap in core material
with
Like
Put a layer of csm over the side that will be pressed to the deck. Scuff that up well before bonding.
Mar 1, 2026
D
DeepCMark58A
Nobody fishing?
Last house off the lake this afternoon, it's over.
Mar 1, 2026
matt167
Mar 1, 2026
Bugzilla46310
reacted to
Bottom Mapping's post
in the thread
Aluminum Boat Paint
with
Like
We had a dealer Rhino- line a 1972 Smoker Craft that had never been painted. The shop went into a song and dance about custom work and...
Mar 1, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I was never concerned, knowing you got your hands full. Tomorrow is fillets and tabbing of the transom. Tuesday, I am going to pick up...
Mar 1, 2026
J
Jeff J
Some of the I/Os I have seen have a toggle switch. The lanyard will flip the switch to off if used otherwise it causes problems because...
Mar 1, 2026
Are the pics your manifold and Throttle body, with MAP circled?
Mar 1, 2026
