99yam40
replied to the thread
1992 yamaha 2-Stroke 85hp tiller handle lower unit
someone trying to shift while motor is not running can cause the shift shaft to twist. found that on my brothers old C60, along with...
Mar 2, 2026
T
tank1949
posted the thread
Replacing Bravo 1 lower shift cable
in
Mercury MerCruiser Sterndrives & Engines
Is there a video out there showing how to fish the cable through the transom assemblies?
Mar 2, 2026
reacted to
Lou C's post
in the thread
was thinking of changing over to a Delco EST system from points....
with
Like
True, changing over would have taken away some of my Luddite pleasure.
Mar 2, 2026
reacted to
alldodge's post
in the thread
with
Like
Forgot a point Lou you wouldn't be able to tell us why points are better ;)
Mar 2, 2026
Mercruiser 350 MAG MPI
If throttle is moved move 3/4 to full throttle the ECM shuts off the injectors, so if it was flooding this should allow it to start if...
Mar 2, 2026
T
tphoyt
Trail camera issues fixed, now pics from them ...
😂 great timing.
Mar 2, 2026
C
Crosbyman
Check/Fix/Replace Starter Motor 1996 50hp
one option is take it to a repair shop but here is a typical fix up .
Mar 2, 2026
FLATHEAD
When does Kangaroo season start?
Mar 2, 2026
D
Dano3578
I'm also wondering what else can cause the linkage to be off causing the noise ? I've been told to adjust the linkage near the power...
Mar 2, 2026
F
FishAtFive
reacted to
racerone's post
in the thread
Starts right up sometimes, but other times crank no start
with
Like
I can not see or touch your motor !----The red lever should be inline with the valve body for normal operation.----If I saw 90 PSI here...
Mar 2, 2026
L
lgaytan
Nobody fishing?
Mar 2, 2026
A
AusFox
When I was cranking and trying to use throttle it wouldn't start. Apparently before I got involved the only way they could get it to...
Mar 2, 2026
D
Dano3578
posted the thread
in
Yamaha & Suzuki Outboards
If I remember correctly, when I first bought this motor(5years ago) it always made clicking noise while in neutral and I'd spin the prop...
Mar 2, 2026
L
lgaytan
Nobody fishing?
I went fishing last weekend with a friend and my dad, good weekend I cought 5 decent bass over 3-4 pounds each, my dad as well but my...
Mar 2, 2026
rolmops
Getting impatient
Tomorrow will be the first day with temperatures that are over 40. which means that the snow will start melting at a good clip. Time to...
Mar 2, 2026
