C
crazy charlie
replied to the thread
How to kill mold on billge/engine surfaces
Bleach in a spray bottle will work the best.Regular old bleach, nothing fancy like the "easy pour" or "no drip or easy pour" , just...
Mar 3, 2026
jimmbo
Mercury Tempest, Turning Point Mach 3 or Michigan Wheel Apollo?
5.7. It wasn't offered with the 5.7 but rather with a 5.0 with EFI(horsepower was the same as a 5.7 with a 2bbl Carb), but still, it...
Mar 3, 2026
P
Pmt133
I've worked some miracles with spray 9. The starbrite stuff is good too. Vinegar works, simple green works... like pretty much any mild...
Mar 3, 2026
N
N1NE1
Power trim stalling motor (hpdi )
Yes there is a switch on the side of the motor and one on the throttle control. Yes it’s confusing me too
Mar 3, 2026
A
airshot
reacted to
Ifishmuskie2's post
in the thread
Trailer wheel bearings - standard or stainless
with
Like
Lots of grades of SS some rust some don’t. I never knew trailer bearings are available in SS. I’ve never pulled a rusty bearing out...
Mar 3, 2026
A
airshot
Look for cleaning vinegar, 6% acid, has worked d well for me cleaning/ killing mold. Has not harmed anything so far and actually does a...
Mar 3, 2026
A
airshot
2000’s Bayliner 175 I/O
Most were OMC as Starcraft had the Merc contract....when OMC was going down, Sylvan switched to Merc, but shortly after Sylvan went to...
Mar 3, 2026
9
99yam40
that does not make sense to me. Does the T&T work from both switches? You might try to measure the battery voltage while hitting each...
Mar 3, 2026
JimDirt
Ruh-Roh… a new gear case may be in order
I must be missing something man. I pushed the shift rod down and removed it. I can’t get the pinion gear out. Until it comes out nothing...
Mar 3, 2026
T
tank1949
reacted to
alldodge's post
in the thread
Replacing Bravo 1 lower shift cable
with
Like
Your trying to split a hair but I'll bite Get the boots and clamp from Merc/VP and you will get a quality clamp. Buy one from Sierra or...
Mar 3, 2026
T
tank1949
reacted to
Scott06's post
in the thread
with
Like
OEM shift bellows will come with a ss crimp on band clamp for the shift cable end, SS hose clamp for transom housing end like shown in...
Mar 3, 2026
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
Yeah, doesn't mean I want to screw up though.
Mar 3, 2026
Starbright mildew and stain remover Or CLR mold and mildew remover
Mar 3, 2026
M
MikeSchinlaub
Boats from work.
Mar 3, 2026
garbageguy
reacted to
redneck joe's post
in the thread
Random
with
Like
For all us dorks....
Mar 3, 2026
