redneck joe
replied to the thread
Random
For us needs https://www.facebook.com/share/r/17xYJ85ckk/
Mar 5, 2026
M
Mc Tool
Power trim stalling motor (hpdi )
Is the charging system working ? What does battery voltage drop to whilst using the ptt ?
Mar 5, 2026
redneck joe
Boats from work.
I see the bunks on the shop 'trailer' are strapped on?
Mar 5, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
That's just some extra padding for my seat. Snap On might as well have just used bare plywood.
Mar 5, 2026
M
MikeSchinlaub
Boats from work.
Mar 4, 2026
W
wn6ngp
oil pump location on 90hp 2000 model merc
thanks for that link. My main interest is to get to that gear #18 to see how its wear looks. If it looks worn then I will just block...
Mar 4, 2026
N
N1NE1
reacted to
99yam40's post
in the thread
with
Like
he said they both raise and lower the motor ,but the one on the control causes the running outboard motor to mess up. Not the T&T motor
Mar 4, 2026
redneck joe
Boats from work.
Hope they are doing the cushions as well...
Mar 4, 2026
Fun Times
Mercruiser 350 MAG MPI
Personally, with everything described of the engine defaults and things tried, I'd be concentrating on the MAP sensor from testing of...
Mar 4, 2026
M
MikeSchinlaub
Boats from work.
It was a Smurfin day today.
Mar 4, 2026
S
saltchuckmatt
Check/Fix/Replace Starter Motor 1996 50hp
Without going back through the posts, and assuming this is a remote motor, have you removed the control box plug from the motor and then...
Mar 4, 2026
9
99yam40
Mar 4, 2026
C
The PTT switch on the motor is likely powered directly from the starter solenoid on the engine. About 2' of wire which is pretty well...
Mar 4, 2026
C
Oil Injection on 2 cycle carb or EFI outboard engines is done justbefore the fuel hits the carbs or injectors. Trace your fuel line out...
Mar 4, 2026
C
You can usually test the spark timing with all but one of the spark plugs removed, and a timing light on the remaining spark plug, in...
Mar 4, 2026
