JimS123
posted the thread
Aluminum Boat Paint
in
Boat Topics and Questions (not engine topics)
Just finishing up the restoration of a 60 year old tinny utility. The only thing left is to paint the inside deck (floor). It is green...
Saturday at 1:11 PM
replied to the thread
2000’s Bayliner 175 I/O
Dozens of options on ignition in a 3.0
Saturday at 1:10 PM
reacted to
matt167's post
in the thread
with
Like
Welp looks like I’ll own it. It’s solid. Not kind of solid. It needs some tinkering and repairing. The cabin door needs adjustment. Rear...
Saturday at 1:09 PM
I/O (Sterndrive) Conversion to Outboards
Just don't do a Sonny Bono
Saturday at 1:09 PM
C
Crosbyman
What should the piston psi be on late 70s 2hp outboards?
some motor have a rubber hub that wears out and may slip at wot...
Saturday at 12:53 PM
matt167
Saturday at 12:30 PM
E
Eischman
Most common causes on those little 2hp Evinrudes: Dirty carb jet Weak spark (coil/points) Partially sheared prop pin Okay, I replaced...
Saturday at 12:29 PM
C
Crosbyman
Check/Fix/Replace Starter Motor 1996 50hp
starter circuitry is generally straight forward.. battery B- GROUND is bolted to the engine frame and serves everybody. Red B+...
Saturday at 12:19 PM
C
Crosbyman
here one opinion from ai what would cause a 1978 2hp Evinrude to appear weak at wot if compression is ok If your Evinrude 2 HP...
Saturday at 11:58 AM
P
Pmt133
which laminate is that again... you know, since you're using so many. :p I know what you mean with the resin though. One of the buckets...
Saturday at 11:54 AM
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
This is the biggest single piece of fiberglass (50 x 90") and took a long time . . . probably 2 hours start-2-finish. 100 oz. of resin...
Saturday at 11:47 AM
E
Eischman
Okay?
redneck joe
2026 NFL/CFB News and Nonsense
Slight derail but too cool not to share. Grimes IA where my brother is from. Girls high school basketball...
Saturday at 11:42 AM
R
reacted to
janul15's post
in the thread
with
Like
Also, I must go back to check all the terminology, (terminal labels) on solenoids, I think I have got badly confused.
Saturday at 11:41 AM
R
piston rings are not the issue !
Saturday at 11:40 AM
