aspeck
reacted to
matt167's post
in the thread
2000’s Bayliner 175 I/O
with
Like
Thanks. I did have a thought about looking into transport tags and it looks like the notary closest to the seller does issue them, so...
Tuesday at 6:05 AM
aspeck
reacted to
matt167's post
in the thread
Getting impatient
with
Like
I was getting nervous as in the past I’ve borrowed the plate from a similar boat trailer that I own as most of my trailers have home...
Tuesday at 6:04 AM
P
Pmt133
replied to the thread
Thinking about making a trailer cover... Opinions wanted.
Since this swung off topic a bit, I got two things. First, we're going to (finally) start grading the side of the house and cut the curb...
Tuesday at 5:33 AM
P
Pmt133
95 Sea Ray 230 Sundancer stringer repair
On the moisture meter, if you have a known "dry" piece of wood around, you can use that to set your zero for the meter too... they...
Tuesday at 5:26 AM
Scantic 525
Jonsson 235v6 78vm
Tuesday at 5:18 AM
redneck joe
Random
https://www.facebook.com/share/r/17dj1SH75a/
Tuesday at 5:16 AM
redneck joe
reacted to
Scott Danforth's post
in the thread
Just thought I'd share a nice photo.
with
Like
I remember temps in the 70s ..... It is between 6:30 and 7am
Tuesday at 4:57 AM
redneck joe
The last two posts are very good advice.
Tuesday at 4:56 AM
redneck joe
Random
https://www.facebook.com/share/r/14TP5joETiF/
Tuesday at 4:55 AM
redneck joe
reacted to
dwco5051's post
in the thread
Random
with
Like
Tuesday at 4:54 AM
dingbat
Stator issue ( I believe )
Stator output is AC. A diode in the dva circuit rectifies to DC before charging the capacitor (recording) for peak voltage reading
Tuesday at 4:08 AM
dingbat
B Black is universal color for ground unless it isn’t. A schematic of the circuit will confirm either way.
Tuesday at 3:55 AM
Sylvan Offshore/ Islander V berth. Cushions
some foam and a bit of upholstery to make a new filler cushion.
Tuesday at 3:47 AM
M
markhodges78
There not they are ac but you can't test peak voltage using ac you need to convert it to dc using a dva adapter or dva meter.. to remove...
Tuesday at 3:35 AM
tpenfield
I had rot in both of my Formula boats (a 242 and a 330). It is a 1990's (and earlier) thing across most of the boat brands. First...
Tuesday at 3:23 AM
