B
BOYS & TOYS
reacted to
matt167's post
in the thread
Sylvan Offshore/ Islander V berth. Cushions
with
Like
I found the brochure on the boat and it appears that it never had a fill in section, so I’ll have to make a platform that is self...
Tuesday at 12:00 PM
B
BOYS & TOYS
reacted to
MNhunter1's post
in the thread
New Journey
with
Like
Tuesday at 11:58 AM
B
BOYS & TOYS
reacted to
MNhunter1's post
in the thread
New Journey
with
Like
Tuesday at 11:57 AM
B
BOYS & TOYS
reacted to
MNhunter1's post
in the thread
New Journey
with
Like
Time to bring this thread back to life! Took a little hiatus for awhile due to some unexpected medical issues, but I've been following...
Tuesday at 11:57 AM
M
markhodges78
replied to the thread
Stator issue ( I believe )
there are three wires for the stator Red Blue and Brown.. The black that I am speaking off is from the meter... which test lead goes...
Tuesday at 11:52 AM
D
DeepCMark58A
wall carpet replacement
Get a carpet cleaner and pull the cleaning liquid out with that.
Tuesday at 11:42 AM
M
markhodges78
Yes it is a Yamaha manual / diagram
Tuesday at 11:42 AM
Fun Times
reacted to
Bondo's post
in the thread
New engine will not throttle up 350 mag mpi
with
Like
Ayuh,...... Welcome Aboard,...... Lack of fuel killed the 1st motor, so I'd start there,..... Start at the fuel tank...
Tuesday at 11:41 AM
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
It was Plan B . . . The snow had softened up with the warmer weather to a point where I was able to clear out under the gantry . . . ...
Tuesday at 11:35 AM
D
DFWcobalt
trim cylinder issue
Thank you very much! I'm quite sure the rebuild will be way cheaper than the local cobalt shop asking for 5k to replace the pump and...
Tuesday at 11:33 AM
T
tphoyt
That was the way to go. And it saves more time for refreshments.
Tuesday at 11:33 AM
Fun Times
90 psi compression seems pretty low. That’s actually seems scary for a new engine?…. Something might not be set up correctly internally…...
Tuesday at 11:18 AM
B
boscoe99
A DVA adapter is measuring peak AC voltage but yes the meter gets positioned on the DC setting. Confuses some folks.
Tuesday at 10:58 AM
B
boscoe99
Yamaha does not use any black (ground) wires in AC circuits. DC circuits only. Is that a Yamaha manual diagram?
Tuesday at 10:56 AM
nearly all the cabin boats from the 70's thru 90's used hull liner liberally apply starbrite mildew remover.
Tuesday at 10:52 AM
