reacted to
redneck joe's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Well crap its upside down again so I guess I will just stay confused for a bit longer.
Tuesday at 6:12 PM
redneck joe
replied to the thread
Getting impatient
A bit off topic but prob 20 years ago I was traveling a lot for work and would spend weeks or months at a time in a location with the...
Tuesday at 6:00 PM
redneck joe
Tuesday at 5:51 PM
M
markhodges78
Stator issue ( I believe )
That is the conclusion I come up with
Tuesday at 5:49 PM
dingbat
reacted to
DeepCMark58A's post
in the thread
wall carpet replacement
with
Like
Get a carpet cleaner and pull the cleaning liquid out with that.
Tuesday at 5:28 PM
G
gmach
95 Sea Ray 230 Sundancer stringer repair
I took some core samples as advised. The stringer samples all came out dry fresh wood. I found wet wood in the transom about an inch...
Tuesday at 5:23 PM
trim cylinder issue
$75 for a rebuild kit, takes about an hour If you don't have the pin spanner, it's about $40
Tuesday at 5:11 PM
M
MikeSchinlaub
reacted to
SlipperyOar's post
in the thread
1981 Springbok 18' Restoration/Renovation
with
Like
Just finished the major part of my consoles. Drove solid rivets into the sheets and angle aluminum frame, and welded all of the seams...
Tuesday at 4:30 PM
Lou C
trim cylinder issue
I did the ones on my old Cobra a couple of years ago and as long as you can get the end cap off it’s not a hard job. Parts cost was $52...
Tuesday at 4:07 PM
9
99yam40
Yeah, I always start with compression, spark, and spark timing If all of that is good then chase fuel. maybe he already narrowed it...
Tuesday at 4:05 PM
R
Any other trouble shooting done besides picking on the stator?
Tuesday at 3:52 PM
R
oil pump location on 90hp 2000 model merc
partial teardown of engine is required to replace the gear.
Tuesday at 3:48 PM
Ifishmuskie2
reacted to
SlipperyOar's post
in the thread
with
Like
Tuesday at 3:37 PM
S
SlipperyOar
Tuesday at 3:29 PM
C
Mercury Tempest, Turning Point Mach 3 or Michigan Wheel Apollo?
I currently am running a 21 or a 23 P 3 blade TP Hustler. The 23P prop is a bit faster, but not a lot, and it is a little slower out of...
Tuesday at 3:26 PM
