P
Pmt133
reacted to
Scott Danforth's post
in the thread
95 Sea Ray 230 Sundancer stringer repair
with
Like
We are here for moral support as well as technical. you have this. you are already past the first step
Today at 8:55 AM
P
Pmt133
reacted to
gmach's post
in the thread
with
Like
I'll have a better idea of how bad the rot is after pulling the engine. The way things are going, I have a feeling it's not going to be...
Today at 8:55 AM
replied to the thread
Today at 8:54 AM
P
Pmt133
Family of 5, 19ft or 21ft?
I used to do 6 on the 4 winns no problem. Before the repower. 4 was comfortable. 6 doable but you had to get creative with locations of...
Today at 8:54 AM
BWR1953
Been a little cold.
I'm probably gonna have to cut the grass this coming weekend. :cool:
Today at 8:53 AM
M
Mc Tool
reacted to
redneck joe's post
in the thread
Random
with
Like
For all you Yankees., I hope this is one thing you do in the winter.... https://www.facebook.com/share/v/1DpPrNtS7g/
Today at 8:52 AM
G
gmach
Today at 8:50 AM
depends on the boat, the size of the people and the water you are boating in. I had 2 younger daughters that would bring their friends...
Today at 8:44 AM
redneck joe
When they did mine, they cut the hole a bit larger and fiberglassed the exposed wood.
Today at 8:41 AM
trim cylinder issue
these can work, however are more expensive than the correct ones. these do not work that well, however I have used them. just takes...
Today at 8:39 AM
M
mr 88
21' is going to be a much better ride in any sort of chop . You'll have room for coolers and gear , not so much in a 19' . Two feet is a...
Today at 8:34 AM
trim cylinder issue
only if it fits. this is the pin spanner that I had to use on my VP cylinders. I also had to modify it to fit around the shaft.
Today at 8:33 AM
P
Pmt133
reacted to
in the thread
Been a little cold.
with
Like
my doc says its Chronic Rhinosinusitus and since I suffer so bad, he suggested moving out of Florida. Pollen is so thick the car is...
Today at 8:33 AM
E
Eischman
What should the piston psi be on late 70s 2hp outboards?
Thanks for the reply! Unfortunately, I cannot do any sea tests until boating season arrives in WI In the meantime, Ill check the carbs...
Today at 8:25 AM
E
Eischman
reacted to
Crosbyman's post
in the thread
with
Like
ok next... my brother had one of the " problematic" 2hp... turned out the carb had a hard to see crack in the carb body . I don't...
Today at 8:19 AM
