P
Pmt133
reacted to
Scott Danforth's post
in the thread
95 Sea Ray 230 Sundancer stringer repair
with
Like
in a few weeks when you are itchy and waking up with nightmares of moldy wood and foam, we will be here too. pro tip. a 3" diameter...
Today at 11:45 AM
replied to the thread
Today at 11:43 AM
G
gmach
Thank you all, I really appreciate your support. It's good to be able to talk to people that understand what I'm up against. Most of the...
Today at 11:39 AM
A
awreneau
posted the thread
back grind clutch dog on 74 15hp Johnson 15r74g
in
Johnson & Evinrude Outboards
I have the mentioned motor and under load it pops out of gear. My suspicion is the clutch dog, but Ive been told to check the detent...
Today at 11:36 AM
1981 Rinker with Mercruiser 120HP, In what order should I do these repairs??
3 - Replace all bellows 2 - Replace trim limit wires leave switches hanging 1 - Replace lower shift cable 4 - Install trim limit and...
Today at 11:34 AM
Verado 5.44 Pinion height tool
Read our rules @weprint closed
Today at 11:31 AM
W
weprint
I realize that this is an old post but could you supply the dimensions? Thanks.
Today at 11:29 AM
C
Crosbyman
What should the piston psi be on late 70s 2hp outboards?
to test at wot the garbage can may not be adequate due to fumes and high prop slip in aerated water . maybe just a qwick burst to...
Today at 11:26 AM
T
tphoyt
Been a little cold.
I won’t have to worry about pollen until May. It never bother me until about 5 years ago and now it’s a little worse every year. I...
Today at 11:11 AM
Scott06
in addition to what Scott said - get a factory manual step by set this is all outlined. Also this is a good place to use OEM parts. I...
Today at 11:05 AM
reacted to
tpenfield's post
in the thread
with
Like
It is like the 5 phases of grief . . . Denial Anger Bargaining Depression Acceptance
Today at 10:45 AM
tpenfield
Today at 10:44 AM
A
airshot
Run them in a garbage can or other large tank of water. When you can get on the water, why not swap props and see if they push the...
Today at 10:41 AM
WIMUSKY
2026 NFL/CFB News and Nonsense
Miami's fan base must be happy... https://www.cbssports.com/nfl/news/falcons-signing-tua-tagovailoa-nfl-free-agency/
Today at 10:39 AM
M
MikeSchinlaub
Yeah, that's right about at the bottom edge of the transom. Since you'll have to cut the bottom half off anyway, just do the whole...
Today at 10:35 AM
