M
Mc Tool
replied to the thread
Just thought I'd share a nice photo.
Or a escalator and a durry Jandals thongs and flip flops 😁
Apr 5, 2026
M
Mc Tool
Lower Unit Oil Leak
Oil leaks tend to wick along surfaces and gaps and this can make it hard to figure where its coming from , usually you would give it a...
Apr 5, 2026
1lastweekend
1981 MC-1 driveshaft reinstall into upper housing- any tricks to this?
Thanks, I will try that too if the clamp doesn't help...Did you use a heat gun or a torch? So you flipped the housing on its back and...
Apr 5, 2026
R
rebuilt
posted the thread
'84 90hp crossflow. J90 MLCRD. Reed valve filler blocks. part # 0322684. When?
in
Johnson & Evinrude Outboards
How to tell it they are warped enough to replace? I'm installing new CCMS reeds with stuffers. These blocks are still soft and pliable...
Apr 5, 2026
1lastweekend
reacted to
kenny nunez's post
in the thread
with
Like
I have had to apply heat to the housings several times. With the housing positioned so that gravity will help give heat a shot. Just be...
Apr 5, 2026
K
kenny nunez
Apr 5, 2026
tpenfield
Tiny boat performance help
Even or only a slight downward angle would be all that I would do . . . Too much angle will tend to slow the boat down more than desired
Apr 5, 2026
1lastweekend
reacted to
nola mike's post
in the thread
1981 Rinker with Mercruiser 120HP, In what order should I do these repairs??
with
Like
Not a press fit but can be a bit fiddly. If you're not square going in I could see it jamming if you force it.
Apr 5, 2026
1lastweekend
reacted to
alldodge's post
in the thread
with
Like
Manual says to use a hose clamp. If the sleeve is wider it may not have the bearings it correct position
Apr 5, 2026
1lastweekend
Yeah I hope not, but I set up this clamp and rubber pieces to check...My calipers dont go down far enough into the housing to measure...
Apr 5, 2026
redneck joe
Well I prefer and elevator to a lift and a smoke versus a fag and...
Apr 5, 2026
redneck joe
Ted will answer better than me but if you go more than hull it will a.ways nose you down so if once on plane you don't need nose dow...
Apr 5, 2026
1lastweekend
reacted to
alldodge's post
in the thread
with
Like
Take just the race and see if it fits, hope the housing isn't warped
Apr 5, 2026
K
kalebsheridan
Awesome I may have to make some! Would they run so they are flat with the hull of the boat? Or should they have some angle to them?
Apr 5, 2026
JimS123
Lower Unit Oil Leak
Gotcha. I never pulled a lower unit before. I just assumed that there was gear oil back there. It's not green, so I'm guessing it's...
Apr 5, 2026
