E
E130 chad
posted the thread
E130txAOR timing issue but runs
in
Johnson & Evinrude Outboards
hello to all! have a 1995 Evinrude 130 that I recently purchased. Before trying to get it to fire I did some checks and has perfect...
Apr 5, 2026
JimS123
replied to the thread
Lower Unit Oil Leak
I guarantee that not a drop was spilled. This is the easiest engine I ever did an oil change on. The drain plug is on the side of the...
Apr 5, 2026
R
1987 50hp Evinrude E50TLCUD Thermostat Replacement
Those are a looper style since 1971
Apr 5, 2026
reacted to
1lastweekend's post
in the thread
1981 MC-1 driveshaft reinstall into upper housing- any tricks to this?
with
Like
Yes!!! Got it in, just hit the inside of the housing with a torch for 60 seconds or so!
Apr 5, 2026
reacted to
kenny nunez's post
in the thread
with
Like
Now you learned a new trick! Good job!
Apr 5, 2026
K
kenny nunez
Apr 5, 2026
Stinnett21
Trailer tires.
I've been running Hankook Vantra for around 5 years. No issues.
Apr 5, 2026
flashback
Almost there
I had a pump housing rust out from the inside and dripped fluid into the bilge. I guess it had got water inside somehow.
Apr 5, 2026
1lastweekend
1981 Rinker with Mercruiser 120HP, In what order should I do these repairs??
Thanks, I hit the inside of the housing with a propane torch for 60 seconds and the whole thing slid right in!
Apr 5, 2026
1lastweekend
Apr 5, 2026
D
dalmontom
posted the thread
Removing a 1979 Grady White steering bezel
in
Boat Topics and Questions (not engine topics)
Hi, I’m looking for help removing a steering bezel on my 1979 Grady white? My research said to look for two Phillips head screw to...
Apr 5, 2026
M
MarineSp
Timing too advanced, Johnson 50hp 2-stroke 1996
Good fix! Lapping the flywheel taper is one of those things nobody thinks about but makes a huge diffrence. The rust buildup on the ring...
Apr 5, 2026
M
MarineSp
The seal flange goes toward the thermostat housing (facing outward/away from the block). The flat side seats against the thermostat...
Apr 5, 2026
K
kalebsheridan
reacted to
redneck joe's post
in the thread
Tiny boat performance help
with
Like
Ted will answer better than me but if you go more than hull it will a.ways nose you down so if once on plane you don't need nose dow...
Apr 5, 2026
K
kalebsheridan
reacted to
tpenfield's post
in the thread
with
Like
Even or only a slight downward angle would be all that I would do . . . Too much angle will tend to slow the boat down more than desired
Apr 5, 2026
