1lastweekend
reacted to
Scott06's post
in the thread
1981 MC-1 driveshaft reinstall into upper housing- any tricks to this?
with
Like
amazing what a diff it makes with just a bit of heat. You can do the same getting bearings on shafts etc by heating them. We have a...
Apr 6, 2026
1lastweekend
reacted to
kenny nunez's post
in the thread
with
Like
Now you learned a new trick! Good job!
Apr 6, 2026
C
replied to the thread
E130txAOR timing issue but runs
Two cycle motors can run backwards pretty well. Set the top piston to top dead center using a screwdriver (or piston stop tool) and see...
Apr 6, 2026
C
Lower Unit Oil Leak
Gee, smell the leaking oil. If it stinks like sulfur, it is gear oil. Color can often be misleading.
Apr 6, 2026
FLATHEAD
reacted to
bruceb58's post
in the thread
Trailer tires.
with
Like
On any trailer that I put significant miles on, only Goodyear Endurance or Maxxis. If I am just putting on 25 to 50 miles a year as my...
Apr 6, 2026
FLATHEAD
reacted to
Pmt133's post
in the thread
Trailer tires.
with
Like
Last set I put on the boat trailer was hercules which are made by Cooper out in Ohio. My guy reccomended them and they're popular in the...
Apr 6, 2026
Removing a 1979 Grady White steering bezel
look on the back-side of the console
Apr 6, 2026
Scott06
Apr 6, 2026
BWR1953
reacted to
redneck joe's post
in the thread
Almost there
with
Like
It's fine. It's all fine
Apr 6, 2026
C
Crosbyman
OK a question. I have a little 1984 Evinrude 7.5 HP.. Beautiful motor.
I did change the lower unit grease and it looked real good. oil hopefully...
Apr 6, 2026
P
Pmt133
Trailer tires.
Apr 6, 2026
redneck joe
Trailer tires.
Do not take this thread political.
Apr 6, 2026
Bugzilla46310
Trailer tires.
Possibly true but why do anything that supports that country.
Apr 6, 2026
redneck joe
Almost there
Apr 6, 2026
redneck joe
You will not get on plane with the kicker, you will be fine tho not as efficent
Apr 6, 2026
