aspeck
reacted to
matt167's post
in the thread
Eagle Claw Starfire X trolling combo’s. Any good ( enough )?
with
Like
I was in town yesterday so I picked up one of the Eagle claw combo’s. They listed they had 4 in stock but one was it. I also grabbed a...
Apr 6, 2026
R
rebuilt
replied to the thread
'84 90hp crossflow. J90 MLCRD. Reed valve filler blocks. part # 0322684. When?
Maybe mine aren't in bad enough shape to worry about. The used ones on eBay didn't look any better.
Apr 6, 2026
A
airshot
How to kill mold on billge/engine surfaces
I spray it on full strength and heavy, let sit overnite. If mold is heavy I will use a brush to loosen it up, rinse and repeat. The...
Apr 6, 2026
A
airshot
reacted to
jlh3rd's post
in the thread
Trailer tires.
with
Like
Yep to all this. My tires are the 10" so I'm double sure with top ratings and inspections.
Apr 6, 2026
Just thought I'd share a nice photo.
MTV from then they actually played music?
Apr 6, 2026
reacted to
alldodge's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Since there are 4 flat prior to radius, start with a circle saw with carbide blade
Apr 6, 2026
flashback
X14
Apr 6, 2026
Apr 6, 2026
What kind of dashcams is everyone using?
Yes, the the socket stays hot, unplug it
Apr 6, 2026
reacted to
Scott06's post
in the thread
1981 MC-1 driveshaft reinstall into upper housing- any tricks to this?
with
Like
amazing what a diff it makes with just a bit of heat. You can do the same getting bearings on shafts etc by heating them. We have a...
Apr 6, 2026
T
tphoyt
I’m a big fan of the Diablo blades.
Apr 6, 2026
Lou C
Trailer tires.
I also go by the company’s rep. Kenda Tire has been in business since 1962, based in Taiwan. I had good luck with those so will probably...
Apr 6, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
I did some cutting of the transom today . . . Went through a bunch of saw blades, metal cutting and carbide for the most part. . . ...
Apr 6, 2026
M
mckaras
reacted to
alldodge's post
in the thread
Installing Water Heater w/ closed loop 8.1 engine?
with
Like
In a house Cold comes in and Tees so cold travels on to all cold faucets and the other side goes into the hot water tank. It comes out...
Apr 6, 2026
M
mckaras
Got it, thank you for the clarification alldodge!
Apr 6, 2026
