dingbat
replied to the thread
Trailer tires.
I’ve only had one tire failure on a trailer in 30+ years. Cut a corner too sharp, blowing the sidewall out in the process on the way to...
Apr 7, 2026
P
Pmt133
2025 Splash of the Year Nominations!
I told the girl all said and done, including engine parts, cabin upholstery and the rest of the crap it neared 20k to fix everything. At...
Apr 7, 2026
does the admiral know you have a spreadsheet? we will take beer as hush money
Apr 7, 2026
dingbat
reacted to
bruceb58's post
in the thread
Trailer tires.
with
Like
The ones in the size I need are made in China...at least 2 years ago when I bought them!
Apr 7, 2026
P
Pmt133
So I had a spread sheet for a lot of the supplies pre covid. The glass, foam and resin didn't change all that much. The rest changed...
Apr 7, 2026
P
Pmt133
reacted to
88 Capri (2022 SOTY)'s post
in the thread
with
Like
I totally agree Scott, I do know with the increased costs of restoration supplies I probably couldn't afford to do it now.
Apr 7, 2026
Not so sad boater
No spark 55 HP Evinrude triumph 1969
Alright folks, $435 later and now Im waiting for the new amplifier to arrive. I will post the results here afterwards.
Apr 7, 2026
tpenfield
95 Sea Ray 230 Sundancer stringer repair
Do the 'burn an inch' technique to get a more exact measurement, but generally you want the core to have been 1.5" . . . looks like you...
Apr 7, 2026
FLATHEAD
reacted to
aspeck's post
in the thread
cooking
with
Like
Her is one of 2 I did. The 2 fed 24 with leftovers. A coffee, garlic, onion, pepper and sea salt rub. Smoked with hickory for 4.5...
Apr 7, 2026
1989 omc cobra gear case problem
Is the propeller shaft too high or the pinion shaft too low? Is the pinion gear positioned correctly on the pinion shaft? Ie: not being...
Apr 7, 2026
Apr 7, 2026
reacted to
Scott Danforth's post
in the thread
with
Like
My guess is that during Covid, we saw a significant bump in splashes, then inflation went nuts and peoples income didnt follow. in the...
Apr 7, 2026
jimmbo
1996 evinrude 40 tiller carb roller
Are you referring to #21? If so the Part # I found was: https://www.marineengine.com/newparts/part_details.php?pnum=OMC0432572
Apr 6, 2026
jimmbo
How to kill mold on billge/engine surfaces
Here, Pickling Vinegar is 7 1/2% and Cleaning Vinegar is 10% Acidic Acid
Apr 6, 2026
S
saltchuckmatt
I couldn't find that part for your motor but maybe I missed it. Is that your cam roller for the throttle? If so, it should go on or not...
Apr 6, 2026
