A
airshot
reacted to
saltchuckmatt's post
in the thread
VRO Pump Question
with
Like
Perfect answer. Many videos on it and always buy the best quality parts that are out there....usually OEM.
Apr 8, 2026
S
saltchuckmatt
replied to the thread
What is this nipple inside the carb area
It shows it as a drain....also shows a rubber cap on it. Right now it could be a vacuum leak I guess.
Apr 8, 2026
S
saltchuckmatt
I'm thinking that goes to the plastic air box for pollution control...not sure where the primer goes into that motor. Not 100 percent...
Apr 8, 2026
S
saltchuckmatt
Is my motor sitting to low?
Maybe...is that a false hollow bottom? Anti cavitation plate should be even with the bottom of your motor is clamped to the transom...
Apr 8, 2026
rolmops
type and color of paint of Starcraft Islander.
So I am making some progress, The stern is all sanded and primed. For the top paint I picked Pettit EZPoxy which while maybe not the top...
Apr 8, 2026
O
Ozzy613
posted the thread
Trailer Set Up
in
Trailers and Towing
Hey guys and gals, Recently picked up a new to me trailer for my 14’ aluminum V-Hull boat. I have some set up questions and hoping for...
Apr 8, 2026
T
TnTommy
posted the thread
in
Pontoons
I've seen a lot of post about how the top of lower unit should be even with the bottom of transom is my motor too low? It's in the top...
Apr 8, 2026
K
Kwanza
reacted to
Lou C's post
in the thread
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
with
Like
Agree with starting with making sure all the wiring is clean, not corroded at terminals,etc. If you have wing nuts retaining your...
Apr 8, 2026
K
Kwanza
reacted to
alldodge's post
in the thread
with
Like
@kwanza1 noticed in your first post you mentioned that you were unable to get into your original account. Guessing it was @Kwanza so...
Apr 8, 2026
K
Kwanza
reacted to
Grub54891's post
in the thread
with
Like
Sounds lik your alternator is bad, but I would be removing and cleaning all battery connections completely, in clouding the grounds on...
Apr 8, 2026
dwco5051
Random
Guess I will have to use this one then.
Apr 8, 2026
tpenfield
reacted to
Scott Danforth's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
similar over-build as my Rogue
Apr 8, 2026
dwco5051
reacted to
aspeck's post
in the thread
Random
with
Like
or you never looked that good or caught a fish that big ... :p Miss seeing your ugly mug! We got to get out on the water together...
Apr 8, 2026
C
VRO Pump Question
Gee, I always liked my OMS system. You get a fresh gas-oil mix all the time. The motor always idles and runs smooth. I replaced the...
Apr 8, 2026
reacted to
MarineSp's post
in the thread
with
Like
Alldodge's wiring diagram is spot on — on the GLP-D the fuel pump is electric and gets its power routed through the alternator circuit...
Apr 8, 2026
