K
Kwanza
replied to the thread
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Thank you, will work through this!
Apr 8, 2026
K
Kwanza
Thank you, hopefully we will up and running, and back to 14 V on the gauge!
Apr 8, 2026
K
Kwanza
Thank you for the useful info. Whether I have a mechanical pump or not, not sure, I can only see a single fuel line coming from what I...
Apr 8, 2026
K
KXP
posted the thread
89 force tilt and trim valve body
in
Force & Chrysler Outboards
Hello I read a bunch of posts . My tilt and trim system was dropping slowly after pick up so I ordered a valve body my old one had a o...
Apr 8, 2026
F
FishAtFive
1987 50hp Evinrude E50TLCUD Thermostat Replacement
Ok reporting back from the dock. Still has the problem of bogging down in gear. The bogging down problem is new, it started the last...
Apr 8, 2026
Trailer tires.
The guideline from most tire companies are to replace at 6 years from tire manufacture date. In the case of Michelin 10 years from...
Apr 8, 2026
Trailer tires.
I fail to see the reason you care a whole lot about tires. You could put the cheapest tires on there.
Apr 8, 2026
E
Evinrudej
‘91 merc 60hp hitting wot rpm??
Cylinder top: 131 Cylinder middle: 135 Bottom: 137 Spark is fine this outboard uses the ngk non resistor spark Tachometer and...
Apr 8, 2026
K
KenOverton33
Need help with ID
Finally had a chance to explore further. The carb has no numbers except for the throttle butterfly, and that is 180. It only has Mikuni...
Apr 8, 2026
aspeck
reacted to
dwco5051's post
in the thread
Random
with
Like
Guess I will have to use this one then.
Apr 8, 2026
D
DeepCMark58A
reacted to
BWR1953's post
in the thread
Just thought I'd share a nice photo.
with
Like
A pic I took late this morning on a windy, rainy day through a rainy window some 70 feet away, of the male Eastern Bluebird on his...
Apr 8, 2026
redneck joe
Not a pic and not mine but loons speak to at a visceral level. https://www.facebook.com/share/r/1ApmWeraS7/
Apr 8, 2026
redneck joe
reacted to
BWR1953's post
in the thread
with
Like
Apr 8, 2026
BWR1953
Apr 8, 2026
BWR1953
reacted to
southkogs's post
in the thread
with
Like
MOD warning: let's get back to posting nice photos and leave the rest alone in this thread. Would hate to have to lock this one down...
Apr 8, 2026
