tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
I still use imperial units of measure . . . According to Google . . . "While the U.S. has a policy to adopt the metric system (Metric...
Apr 9, 2026
P
Pmt133
Trailer tires.
Michelin defenders. Expensive but seem to be one of the few I get my money's worth out of. Had a set of hankook tires on my 04 that went...
Apr 9, 2026
FLATHEAD
Just thought I'd share a nice photo.
Great pic. We have tried to attract bluebirds here with not much luck though we seem to have every bird under the sun. They are in the...
Apr 9, 2026
FLATHEAD
reacted to
BWR1953's post
in the thread
with
Like
A pic I took late this morning on a windy, rainy day through a rainy window some 70 feet away, of the male Eastern Bluebird on his...
Apr 9, 2026
FLATHEAD
Trailer tires.
What tires did you get 130k miles out of?
Apr 9, 2026
jimmbo
‘91 merc 60hp hitting wot rpm??
So you are saying the Spark does indeed jump a 3/8" Gap?
Apr 9, 2026
P
Pmt133
Trailer tires.
I've noticed on vehicles around the 5 year mark the driving characteristics are severely changed from new. That's about as long as I get...
Apr 9, 2026
K
Kwanza
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Update: connected a fused line from battery plus terminal to the sensing port of the alternator (which shows 0 V, and it should show 12...
Apr 9, 2026
K
Kwanza
Thank you, will work through these steps!
Apr 8, 2026
K
Kwanza
Thank you, will work through this!
Apr 8, 2026
K
Kwanza
Thank you, hopefully we will up and running, and back to 14 V on the gauge!
Apr 8, 2026
K
Kwanza
Thank you for the useful info. Whether I have a mechanical pump or not, not sure, I can only see a single fuel line coming from what I...
Apr 8, 2026
K
KXP
posted the thread
89 force tilt and trim valve body
in
Force & Chrysler Outboards
Hello I read a bunch of posts . My tilt and trim system was dropping slowly after pick up so I ordered a valve body my old one had a o...
Apr 8, 2026
F
FishAtFive
1987 50hp Evinrude E50TLCUD Thermostat Replacement
Ok reporting back from the dock. Still has the problem of bogging down in gear. The bogging down problem is new, it started the last...
Apr 8, 2026
Trailer tires.
The guideline from most tire companies are to replace at 6 years from tire manufacture date. In the case of Michelin 10 years from...
Apr 8, 2026
