tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Yes, on the sealing up of the balsa . . . I usually use some resin for that purpose.
Apr 9, 2026
flyingscott
reacted to
Chris1956's post
in the thread
VRO Pump Question
with
Like
Gee, I always liked my OMS system. You get a fresh gas-oil mix all the time. The motor always idles and runs smooth. I replaced the...
Apr 9, 2026
legalfee
reacted to
redneck joe's post
in the thread
Almost there
with
Like
It's fine. It's all fine
Apr 9, 2026
BWR1953
Just thought I'd share a nice photo.
I learned that they're very particular about their housing requirements. They want the bluebird house mounted 6 to 8 feet above the...
Apr 9, 2026
Grub54891
reacted to
dwco5051's post
in the thread
Random
with
Like
Since I have reached the age where “died unexpectedly” will probably not be in my obituary I have been thinking what it should look...
Apr 9, 2026
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
The left side (12V from Bat) wire is what should go to the choke coil on carb Peal the insulation tubing back from wire on the right to...
Apr 9, 2026
K
Kwanza
Thank you. I have to correct my earlier update. The fused line from Battery+ was not connected to the alternator terminal where the...
Apr 9, 2026
Watermann
reacted to
DWbaseball's post
in the thread
1976 22' SUS O/B "Hydration Break"
with
Like
Hey everyone. I wanted to share some pics of my latest boat project, a permanent ladder off the stern that goes over the splashwell...
Apr 9, 2026
P
Pmt133
Trailer tires.
My girls corolla wears evenly as well to the point I also don't rotate them. I only really notice on my truck the outside edges on the...
Apr 9, 2026
P
Pmt133
reacted to
dingbat's post
in the thread
Trailer tires.
with
Like
Just had a third set of Defender 2 on my daily (Civic) last week. Got 63k out of the last set. Put upper 50k’s on the previous two...
Apr 9, 2026
dingbat
Trailer tires.
Apr 9, 2026
Watermann
Vent Hose Flange Question
Yeah factory style vents made in the 70's won't be found today, most today are stainless and plastic.
Apr 9, 2026
P
Pmt133
Trailer tires.
Yeah. On those michelins it was like a switch. Went down hill quick but were still very good. Just no longer great. I probably could've...
Apr 9, 2026
P
Pmt133
reacted to
Lou C's post
in the thread
Trailer tires.
with
Like
I think that's common, the rubber is starting to oxidize and dry out and becomes stiffer, so you lose grip. Especially noticeable in wet...
Apr 9, 2026
Your motor does not have a mechanical fuel pump You have a break in a connection, don't know if that is inside the ALT or a wire. What...
Apr 9, 2026
