Ifishmuskie2
reacted to
83bluefin's post
in the thread
1983 Blue Fin 16’ Resto
with
Like
Started the other night on the trailer. Redneck heaven I swear. Connections with wire nuts, duct tape, and spade connections. It’s a...
Apr 9, 2026
T
Tonester
posted the thread
1987 Mercury Black Max XR2 150hp - Stator Testing
in
Mercury & Mariner Outboards
First time boat owner and I have spent a lot of time trying to diagnose the issues with my outboard. First thing I noticed is that the...
Apr 9, 2026
Ifishmuskie2
replied to the thread
Trailer Set Up
How heavy is the boat? If it’s less than 800 lb then launch and load shouldn’t be very hard. Yes the winch needs to be raised...
Apr 9, 2026
flashback
reacted to
Pmt133's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Looks good sir. Color match is a wee bit off though. :p
Apr 9, 2026
C
Crosbyman
Is my motor sitting to low?
is this a new to you rig when this this concern suddenly come up ?? any symptoms ... what is the rig doing or not dowing
Apr 9, 2026
R
1983 Evinrude 15 how to remove drive shaft
Have a 79 model with same issue here.------Took engine apart.---May cut / grind the crank to save the shaft.-----The splines should be...
Apr 9, 2026
C
Crosbyman
flip the engine upside down an drip some release agent down the shaft to reach the PH let it seep in a few hrs and retry. tapping...
Apr 9, 2026
tpenfield
The extension bracket needs a tweak . . . After much effort, the extension bracket would not come all the way flush with the boat's...
Apr 9, 2026
tpenfield
Needs a Thx . . . I have no plans for the trailer, other than some tongue weight adjustment.
Apr 9, 2026
J
jlh3rd
reacted to
dingbat's post
in the thread
Trailer tires.
with
Like
Just had a third set of Defender 2 on my daily (Civic) last week. Got 63k out of the last set. Put upper 50k’s on the previous two...
Apr 9, 2026
J
jlh3rd
Boat Cover Repair?
I ordered a small roll of marine canvas, white, to patch my custom pontoon cover. I use the "5200" and Goop makes a marine grade glue...
Apr 9, 2026
J
jlh3rd
not a false bottom, just the end of the motor pod for a pontoon. Mine is just an open rectangle, no vertical structures. As mentioned, a...
Apr 9, 2026
P
Pmt133
reacted to
bruceb58's post
in the thread
Trailer tires.
with
Like
They are Goodyear Wramglers. Haven't decided if I will get Michelin Defender street tire or at AT tire again. This vehicle is only...
Apr 9, 2026
M
mjwag
reacted to
Chris1956's post
in the thread
Support for new floor
with
Like
That is similar to my speedboat in design. I repaired it the way Mikeshinlaub suggested. After the new foam is installed and trimmed...
Apr 9, 2026
M
MarineSp
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Good news is the alternator itself is fine since it charges at 14V once backfed. Alldodge is right about peeling back that insulation —...
Apr 9, 2026
