roscoe
replied to the thread
1983 Blue Fin 16’ Resto
Congrats on the new adventure. That hull was made by StarCraft- sylvan-smokercraft. It should be a good one. 16’ or 18’ - ??? ALSO—-...
Apr 9, 2026
I/O (Sterndrive) Conversion to Outboards
You have two tapered surfaces coming together. The 0.020-0.030" of gel on the hull is probably the issue. I don't have the angles, but...
Apr 9, 2026
D
DeepCMark58A
posted the thread
Paintball gun
in
Dockside Chat
I need one, I want automatic and accurate. I am not competing or playing paint ball.
Apr 9, 2026
redneck joe
Been busy with the new house and the current house getting ready to close and while I appreciate all the technical stuff (Ted are you...
Apr 9, 2026
tpenfield
I don't understand what you are saying :unsure:
Apr 9, 2026
J
jlh3rd
Boat Cover Repair?
if you can find a shop....then find one close......then wait......then repeat when the next repair is needed. gluing the strip on the...
Apr 9, 2026
With the taper, you probably are the gel thickness of the hull sides in the two areas port and starboard of the old out drive area
Apr 9, 2026
M
MikeSchinlaub
Boat Cover Repair?
Just take it to an upholstery shop. It'll probably only cost about $50 to have it sewn up, and it'll be a much better repair than an...
Apr 9, 2026
J
Jeff J
reacted to
FLATHEAD's post
in the thread
Trailer tires.
with
Like
I generally use cooper at3 discoverer on my truck. I get a good ride decent longevity and traction when I need it. I get in the mud...
Apr 9, 2026
Ifishmuskie2
reacted to
83bluefin's post
in the thread
with
Like
Started the other night on the trailer. Redneck heaven I swear. Connections with wire nuts, duct tape, and spade connections. It’s a...
Apr 9, 2026
T
Tonester
posted the thread
1987 Mercury Black Max XR2 150hp - Stator Testing
in
Mercury & Mariner Outboards
First time boat owner and I have spent a lot of time trying to diagnose the issues with my outboard. First thing I noticed is that the...
Apr 9, 2026
Ifishmuskie2
Trailer Set Up
How heavy is the boat? If it’s less than 800 lb then launch and load shouldn’t be very hard. Yes the winch needs to be raised...
Apr 9, 2026
flashback
reacted to
Pmt133's post
in the thread
with
Like
Looks good sir. Color match is a wee bit off though. :p
Apr 9, 2026
C
Crosbyman
Is my motor sitting to low?
is this a new to you rig when this this concern suddenly come up ?? any symptoms ... what is the rig doing or not dowing
Apr 9, 2026
R
1983 Evinrude 15 how to remove drive shaft
Have a 79 model with same issue here.------Took engine apart.---May cut / grind the crank to save the shaft.-----The splines should be...
Apr 9, 2026
