replied to the thread
I/O (Sterndrive) Conversion to Outboards
smear a bit of blue or yellow snap-line chalk on the boat hull surfaces. then look for transfer to the extension
Apr 10, 2026
tpenfield
Something isn't right . . . My geometry calc's are indicating that the extension bracket would have to be off by about 3/4" on the width...
Apr 10, 2026
fluidboat
Fuel Line USCG Type for Under RIB Floor
You are routing fuel from a bow locker tank → under the floor → transom water separator → engine. That “under the floor” section is...
Apr 10, 2026
K
Kwanza
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
An update on the above issue. I will probably wait until I can take the boat to the mechanic, as I am afraid of doing further...
Apr 10, 2026
M
Mc Tool
Paintball gun
Oh yeah ....neighbours dog problems ? 😁 You can get solid clay balls ,which are great for dogs coz they dont leave any witness marks .
Apr 9, 2026
J
Jacobnya
1989 omc cobra gear case problem
not sure about the nut being tightened or not but ill definitely ask about that
Apr 9, 2026
J
Jacobnya
what he is telling me is when he put the pinion bearing housing on he cant tighten the bolts cause it prevents the propeller shaft not...
Apr 9, 2026
N
Nordin
reacted to
racerone's post
in the thread
1983 Evinrude 15 how to remove drive shaft
with
Like
Have a 79 model with same issue here.------Took engine apart.---May cut / grind the crank to save the shaft.-----The splines should be...
Apr 9, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
with
Like
When I made the transom mating surfaces, I used corrugated cardboard as a 'padding' to mimic the thickness of fiberglass. . . . Of...
Apr 9, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
with
Like
Needs a Thx . . . I have no plans for the trailer, other than some tongue weight adjustment.
Apr 9, 2026
B
BOYS & TOYS
reacted to
rolmops's post
in the thread
type and color of paint of Starcraft Islander.
with
Like
I was counting on a grand. This boat restoring thing is something I'm really enjoying and it gives me something to look forward to...
Apr 9, 2026
R
rossbar86
posted the thread
Noise after replacing impeller and fuel/water separator
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
I just replaced the impeller and fuel/water separator today and now notice a sort of rhythmic "brushing" or "scraping" sound. Can...
Apr 9, 2026
T
TnTommy
reacted to
airshot's post
in the thread
Is my motor sitting to low?
with
Like
Didn't catch the pontoon part....way different than a boat !
Apr 9, 2026
T
TnTommy
No problem just wondering haven't had boat long
Apr 9, 2026
T
TnTommy
reacted to
jlh3rd's post
in the thread
with
Like
not a false bottom, just the end of the motor pod for a pontoon. Mine is just an open rectangle, no vertical structures. As mentioned, a...
Apr 9, 2026
