tpenfield
replied to the thread
Pushing Run-Flat tires to the limit
My car is a BMW . . . has no spare tire, no car jack, etc. My guess is that with this brand of car, you are not supposed to get your...
Apr 10, 2026
J
jlh3rd
reacted to
dingbat's post
in the thread
early spring maintenance
with
Like
The industry-standard for tightening NPT threads involves counting threads after tightening by hand: 1/8"– 2.0” = Tighten 1.5 to 3...
Apr 10, 2026
matt167
No dipstick on 1989 era 3.0L?
What is an oil I can get locally that I can use? Walmart used to carry QS 25W40 but no more. They still carry the Penzoil 25W40 but I’m...
Apr 10, 2026
J
jlh3rd
Is my motor sitting to low?
point is, it's not a problem until it becomes one. There are basic starting points for rigging/propping a boat but final settings depend...
Apr 10, 2026
Paintball gun
back in the late 90's I worked at a company where 3/4 of the machine shop were in a paint ball club. they made gatling gun paint ball...
Apr 10, 2026
reacted to
DeepCMark58A's post
in the thread
Paintball gun
with
Like
I need one, I want automatic and accurate. I am not competing or playing paint ball.
Apr 10, 2026
I/O (Sterndrive) Conversion to Outboards
smear a bit of blue or yellow snap-line chalk on the boat hull surfaces. then look for transfer to the extension
Apr 10, 2026
tpenfield
Something isn't right . . . My geometry calc's are indicating that the extension bracket would have to be off by about 3/4" on the width...
Apr 10, 2026
fluidboat
Fuel Line USCG Type for Under RIB Floor
You are routing fuel from a bow locker tank → under the floor → transom water separator → engine. That “under the floor” section is...
Apr 10, 2026
K
Kwanza
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
An update on the above issue. I will probably wait until I can take the boat to the mechanic, as I am afraid of doing further...
Apr 10, 2026
M
Mc Tool
Paintball gun
Oh yeah ....neighbours dog problems ? 😁 You can get solid clay balls ,which are great for dogs coz they dont leave any witness marks .
Apr 9, 2026
J
Jacobnya
1989 omc cobra gear case problem
not sure about the nut being tightened or not but ill definitely ask about that
Apr 9, 2026
J
Jacobnya
what he is telling me is when he put the pinion bearing housing on he cant tighten the bolts cause it prevents the propeller shaft not...
Apr 9, 2026
N
Nordin
reacted to
racerone's post
in the thread
1983 Evinrude 15 how to remove drive shaft
with
Like
Have a 79 model with same issue here.------Took engine apart.---May cut / grind the crank to save the shaft.-----The splines should be...
Apr 9, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
with
Like
When I made the transom mating surfaces, I used corrugated cardboard as a 'padding' to mimic the thickness of fiberglass. . . . Of...
Apr 9, 2026
