replied to the thread
I/O (Sterndrive) Conversion to Outboards
Ted, it it helps, the pros also grind to fit
Apr 10, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Checking the measurements on the transom face vs. the extension bracket. . . The width of the top is fine (actually 1/2" to spare) The...
Apr 10, 2026
88 Capri (2022 SOTY)
1989 omc cobra gear case problem
Besides the gears what else did you replace? Do you know what caused the failure? My thinking is could there be damage to the gearcase...
Apr 10, 2026
roscoe
Trailer Set Up
Just buy a new appropriate (taller) winch post and winch. No sense in trying to make that one work, it is used up.
Apr 10, 2026
FLATHEAD
Just thought I'd share a nice photo.
We have been ice free for near three weeks now. Lake surface temps sitting at 51*. Calling for 90 for the high Wednesday. Crazy 😵💫
Apr 10, 2026
roscoe
Stuck floor board over gas tank on Alumacraft
screw 2 eye screws into it, on opposite sides, attach rope, and pull up.
Apr 10, 2026
D
DeepCMark58A
Dang I still have ice on the lake and some snow in the yard, snowed last night.
Apr 10, 2026
S
saltchuckmatt
1983 Evinrude 15 how to remove drive shaft
Stuck driveshaft is very common and tricky to save. Often times when you pull them out the crank splines come with it. Older ones hold...
Apr 10, 2026
M
Mc Tool
When you do the water pump / impeller service
Apr 10, 2026
R
robertjp
posted the thread
in
Boat Restoration, Building, and Hull Repair
Does anybody have any suggestions on getting a floorboard up thats over the gas tank on a 2012 Alumacraft Competitor? I need to replace...
Apr 10, 2026
tpenfield
Apr 10, 2026
FLATHEAD
Was a nice spring day on the lake. Only a matter of days now till you can’t see up in those woods. Fishing was slow. The guy in the pic...
Apr 10, 2026
C
1987 Mercury Black Max XR2 150hp - Stator Testing
CDI Electronics might have a troubleshooting guide for your ign system Make sure it is for your year as stuff changed in the first...
Apr 10, 2026
C
Power steering fluid in bilge?
My neighbor's mercruiser PS cooler rotted out and leaked all the fluid overboard. The boat was impossible to turn at cruise speed. We...
Apr 10, 2026
C
Power steering hoses do leak, usually at the crimped ends. I had to replace them on my Mer cruiser after the crimps on the ends rusted out.
Apr 10, 2026
