JimS123
replied to the thread
Lower Unit Oil Leak
I wiped the oil when I started this thread. Hasn't seeped a drop since.
Apr 10, 2026
JimS123
Trailer Set Up
You definitely need a bow eye. That setup with the eye up that high is certainly odd. I like the idea of the bow roller, but it needs...
Apr 10, 2026
JimS123
Boat Cover Repair?
I ripped a cover once. It was brown cotton twill canvas. My wife's standard sewing machine handled it nicely. She stitched across the...
Apr 10, 2026
tpenfield
I/O (Sterndrive) Conversion to Outboards
The extension bracket is fitting better. I think a 1/2" spacer will do the trick. . Here is the starboard side . . The port side seems...
Apr 10, 2026
K
Kwanza
reacted to
MarineSp's post
in the thread
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
with
Like
The blower dropping voltage from 14V to 12V is a big clue. That means the alternator cant handle even a small extra load — which points...
Apr 10, 2026
88 Capri (2022 SOTY)
1989 omc cobra gear case problem
The pinion gear is drawn up the splined tapered shaft, if it's not tight enough it could possibly cause your issue.
Apr 10, 2026
Ted, it it helps, the pros also grind to fit
Apr 10, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Checking the measurements on the transom face vs. the extension bracket. . . The width of the top is fine (actually 1/2" to spare) The...
Apr 10, 2026
Besides the gears what else did you replace? Do you know what caused the failure? My thinking is could there be damage to the gearcase...
Apr 10, 2026
roscoe
Trailer Set Up
Just buy a new appropriate (taller) winch post and winch. No sense in trying to make that one work, it is used up.
Apr 10, 2026
FLATHEAD
Just thought I'd share a nice photo.
We have been ice free for near three weeks now. Lake surface temps sitting at 51*. Calling for 90 for the high Wednesday. Crazy 😵💫
Apr 10, 2026
roscoe
Stuck floor board over gas tank on Alumacraft
screw 2 eye screws into it, on opposite sides, attach rope, and pull up.
Apr 10, 2026
D
DeepCMark58A
Dang I still have ice on the lake and some snow in the yard, snowed last night.
Apr 10, 2026
S
saltchuckmatt
1983 Evinrude 15 how to remove drive shaft
Stuck driveshaft is very common and tricky to save. Often times when you pull them out the crank splines come with it. Older ones hold...
Apr 10, 2026
M
Mc Tool
When you do the water pump / impeller service
Apr 10, 2026
