F
FishAtFive
reacted to
Crosbyman's post
in the thread
1987 50hp Evinrude E50TLCUD Thermostat Replacement
with
Like
problem of it idling poorly after warming up has never went away idling on all these oldies from cd fd qd etc...relies on drawing...
Apr 11, 2026
F
FishAtFive
reacted to
Mc Tool's post
in the thread
with
Like
Hey FishAtFive, I wouldnt like to see you give up ,I know it can be a real mind#uck and sometimes you do have to down tools (...
Apr 11, 2026
bajaman123
replied to the thread
Paintball gun
Empire Mini Axe is consistently rated best...
Apr 11, 2026
FLATHEAD
reacted to
roscoe's post
in the thread
Trailer Set Up
with
Like
Just buy a new appropriate (taller) winch post and winch. No sense in trying to make that one work, it is used up.
Apr 11, 2026
kbait
1983 Evinrude 15 how to remove drive shaft
I had a stuck 15 and tried everything! Even made a tool with a plate connected to ds and 4 pushing bolts torqued way tight. Then...
Apr 11, 2026
FLATHEAD
Trailer Set Up
You can make that work with some $ and time. If it was mine I’d get rid of the rear roller. That boat has plenty of support on the bunk...
Apr 11, 2026
R
robertjp
Stuck floor board over gas tank on Alumacraft
would you be able to show me a pic of what you mean by self tappers with grips? Im not following. Thanks
Apr 11, 2026
R
Which kicker mount to install?
Need to fabricate an adapter so that bracket mounts to a flat surface.
Apr 11, 2026
R
robertjp
Its vinyl floor and no I didnt miss any screws. Its never been up before. Wonder if Alumacraft uses some kind of sealant? Which I doubt...
Apr 11, 2026
R
rogerlamb123
Apr 11, 2026
FLATHEAD
reacted to
tphoyt's post
in the thread
Trail camera issues fixed, now pics from them ...
with
Like
This one is on the mend. It must have fallen from the nest.
Apr 11, 2026
P
Pmt133
Pushing Run-Flat tires to the limit
That's not just a Maryland thing. I'm pretty convinced directionals in general are just an option. That beings said, it's on the book...
Apr 11, 2026
C
Crosbyman
Apr 11, 2026
T
tphoyt
Apr 11, 2026
dingbat
Your assuming that blinkers are a thing…lol Maryland doesn’t require the use of blinkers when changing lanes or making a turn from a...
Apr 11, 2026
