WIMUSKY
reacted to
tphoyt's post
in the thread
Trail camera issues fixed, now pics from them ...
with
Like
This one is on the mend. It must have fallen from the nest.
Apr 11, 2026
WIMUSKY
reacted to
FLATHEAD's post
in the thread
with
Like
Second day in a row. This guy is a stone cold killer. His young are well taken care of.
Apr 11, 2026
WIMUSKY
reacted to
aspeck's post
in the thread
with
Like
He must like those tree rats. I always thought they were good eating, just a pain to clean.
Apr 11, 2026
WIMUSKY
reacted to
FLATHEAD's post
in the thread
with
Like
He got another grey squirrel. This fox is a good hunter. 😎
Apr 11, 2026
R
ROY WILLIAMS
replied to the thread
No dipstick on 1989 era 3.0L?
oil 30w. 1989 engine oil. WALMART!
Apr 11, 2026
dingbat
Pushing Run-Flat tires to the limit
Maryland’s law is ambiguous at best. They rewrote the statue in 2016 to make mention of turn signals while at the same time noting...
Apr 11, 2026
C
89 force tilt and trim valve body
Force was bought by Merc, and had Merc gearcases and electronics, at least. Any idea if the valve body is Merc or Chrysler...
Apr 11, 2026
Florida requires turn signals https://www.flsenate.gov/Laws/Statutes/2012/0316.155
Apr 11, 2026
R
rossbar86
Noise after replacing impeller and fuel/water separator
I just started it up and it sounded fine at first, then the sound came back. It almost sounds like it is coming from the power steering...
Apr 11, 2026
rolmops
Which kicker mount to install?
And don't forget to make sure that you have some serious backing under the flat surface to prevent the kicker from damaging that surface.
Apr 11, 2026
Stuck floor board over gas tank on Alumacraft
Most likely zip screws were used Once all the fasteners are out of the floor, it will just raise up. But pretty sure the vinyl must be...
Apr 11, 2026
C
If the QS 25W-40 is NA, you can use SAE 30 detergent motor oil, for moderate climates. You also might look at the OEM recommendations...
Apr 11, 2026
Power steering fluid in bilge?
Could be a bad return line Could be a bad pressure line Could be a bad clamp Could be a bad reservoir Could be a leaking actuator...
Apr 11, 2026
rolmops
Mmmm, interesting.... When inserting the impeller, use some form of lubrication (soap) and turn the impeller forward in the direction of...
Apr 11, 2026
A
airshot
reacted to
Pmt133's post
in the thread
with
Like
That's not just a Maryland thing. I'm pretty convinced directionals in general are just an option. That beings said, it's on the book...
Apr 11, 2026
